Increase the size of Volatile Global PVs Memory, PLC X20CP0484-1
Hey again, everyone.
I’d like to ask about PV memory— is it possible to increase its size in order to create large tables (around 20,000 elements)?
yep sure if we talk about volatile PVs.
In the default sittings i had 65535 Byte and i Icrease it to 800,000 Byte. so it’s possible ?
yes. The size is only limited by available DRAM of this CPU.
Thank you, I really appreciate your response!
