I have a 200 values LineChart created into a MpReport but I do not know how to make timestamp more visible for values.
On X label automatically introduced 7 values for Time (witch is good enough) but It is almost impossible to identify the temperature at 12.31.29 for example.
Is there a way to make more visible the points with timestamps? TO change the style or something else?
Hi @kovarj , unfortunately I was not able to find a solution. The operator is not complaining about it, but I am not very happy with this graph. My conclusion was that is not possible for now, or at least not from AS4.12
Im sorry about that. Did you try to contact local B&R support? if they do not provide solution they can at least record request for improvement. More requests from application field = bigger chance for implementation.
