Logging in with tokens to mapp View & mapp Services, Collection of Use Cases & Requirements
Hello B&R Community,
Our development team is excited to announce that we’re starting work on implementing RFID token-based login to B&R systems (mapp View, mpUserX). This is a feature that many of our B&R users have been eagerly requesting.
To ensure we cover as many real-world B&R user scenarios as possible, we would like to use this cool community and we ask you for your input. This is your unique opportunity to influence how this implementation will take shape.
We’ve prepared a short survey where you can select options or describe your specific use cases.
Please use this link to MS Forms
As you know, the initial analysis phase is crucial and greatly impacts the final product. Take advantage of this chance to have your voice heard. B&R has always been and will always be customer-oriented, and I’m proud to be part of this journey with you.
Thanks in advance for all of your feedback.
Jaroslav
Hi B&R Community,
the survey is still active! Do you have an opinion or idea on how RFID should be implemented? Don’t stay silent, take your opportunity,
we want to hear from you! :blush:
Final call for our survey. We have already collected valuable results. If there is still anyone in the community who would like to contribute, the survey is still open but will be closed soon.
I appreciate feedback from all of you. :slight_smile:
PS: Just out of curiosity, are you, my community colleagues, interested in the results of the survey? If so, mark this reply with a thumbs up and i will prepare it for you :slight_smile:
Summary from survey as I promised:
Thanks all who found time provide us feedback.
Note from me:
  • This survey is used by the Product Owner for planning the development and for proper prioritization
  • None of these results can be taken as a promise of future development. The Product Owner and responsible management must take many additional aspects into consideration
1.What is your main use case with login using token?
2. What is the security need? RFID is (mainly) only a long string identifying a user. Are the any additional “security” measures expected? (TOP 10 selected, summarized using AI)
  1. Encrypted Personal Data: Encrypt personal data on RFID chips; allow RFID tag registration on multiple machines.
  2. Sophisticated Login Devices: Use RFID functions of Android or iPhone for login.
  3. Operators and Roles: Different operators, roles, and safety usage for machines.
  4. Long Strings and Cybersecurity: Start with long strings; later implement cybersecurity measures per IEC62443-4-2.
  5. Password Removal: Remove passwords, use RFID for login; master user manages RFID creation.
  6. Encrypted Data: Encrypt data on RFID chips, especially employee data.
  7. Login and Audit Trail: Use RFID for login and audit trail.
  8. Link UDID to User: Optionally add extra password or pin code.
  9. Encrypted RFID Communication: Use MIFARE Classic Plus or better for secure RFID communication.
  10. RFID Tag Generation: Generate various RFID tags for users from HMI.
3. What type of token you would like to use?
4. How would you like to “create” RFID token?
5. Where RFID reader should be connected?
6. How many RFID readers per application do you need?
7.How many RFID readers per mappView client?
8. Are you interested more about new technology e.g. FIDO2 instead of “stupid” RFIDs?
9. As a machine operator I would like to…(TOP 10 selected, summarized using AI)
  1. Automatic Login with RFID: Use RFID reader integrated into HMI panel to log in automatically; rights applied from existing account.
  2. Easy Login/Logoff: Simplify login and logoff process in mapp View.
  3. Token Login: Log in to machine HMI using a token provided by the line manager.
  4. Password-Free Login: Faster login without needing to remember a password.
  5. Machine Operation and Safety: Log in to operate the machine and lock it for safety during maintenance.
  6. RFID Card Login: Log in using an RFID card to avoid entering a full-length password.
  7. Single RFID Key: Use one RFID key for all machines from the same OEM.
  8. Quick RFID Login: Tap RFID card for quick and effortless login.
  9. Badge Login: Log in by badging the RFID on the reader without changing the HMI page.
  10. RFID-Activated Machine Control: Attach RFID chip to the reader to turn on the machine; remove it to stop the machine.
11.As a application engineer I would like to …(TOP 10 selected, summarized using AI)
  1. Prepared Solution: Provide a ready-made solution with backend configuration and prepared widgets on HMI side.
  2. Token Parameter in Login Widgets: Access a token parameter in mappView login widgets for easy token-based login; integrate token identification with Active Directory or LDAP server in mappUserX.
  3. Easy Function Addition: Add functions without worrying about interfaces.
  4. Drag & Drop RFID Management: Easily manage RFID in mappView with drag & drop, configure styles, permissions, and properties.
  5. Security Level Identification: Identify oneself, set the right security level, and access mappCockpit for read/write and commissioning.
  6. Quick Integration: Integrate RFID technology easily and quickly.
  7. RFID for Multiple Functions: Use RFID for functions beyond logging in.
  8. RFID Configuration: Configure RFID without AsUsb sample; add RFID token to specific users within mappUserX.
  9. Easy RFID Implementation: Implement RFID tags for user control and audit systems; read RFID key numbers and colors for user groups.
  10. Simple and Secure Login: Implement a simple and secure RFID login solution for mappView using mpUserX, supporting multiple screens.
What I would be prefer is, to have the possibility to implement a custom authentication provider. The implementation on the B&R side should be minimal, so that we can implement our own providers. Currently this is not really possible, because we can not change the algorithm in mapp view how login works.
