Machine Vision - Can mapp motion emulate programs
Hello everyone!
I have been reading about mapp vision, and trying to test it, I have followed the “Getting Started” steps (A.S. Help → Machine vision → Mapp Vision → Getting started) and I could configure and transfer the project to simulation, but I wonder if there is a way to “Emulate” the program behavior, most machine vision software has an emulation mode, where you can set a folder path with images, and the emulation inspect them without the need of a physical camera, so, can Automation Studio emulate in this way a set of images?
Greetings.
Hi @alejandro.cruz, yes you can test your vision application without camera. It is called Offline HMI application and it was introduced recently. Check B&R Online Help. Please use the latest mappVision 5.24.
