In case manual upgrade or in rare cases downgrade for ServoSoft database is required the following steps needs to be taken:
1- Select option from the menu bar:
2- Chose the database you want to use in the ServoSoft from the path where you stored it:
3- Press Apply and then OK and the chosen database should be installed.
