MappView/MappService5.16 Implementing OPC UA encryption and user management simultaneously
最近开发中有个需求,需要同时实现OPCUA加密、用户管理、数据审计功能。
目前遇到的情况是:
OPCUA禁止未加密通道(No Security)后用户登录、用户管理功能直接就不能用了,即便正确输入账号和密码也无法登录。请问这个情况无法处理,需要增加什么配置吗?
automatic translation:
During recent development, we encountered a requirement to implement OPC UA encryption, user management, and data auditing simultaneously.
The current situation is as follows:
After disabling unencrypted communication channels (No Security) in OPC UA, the user login and user management functions stop working. Users cannot log in even when the correct username and password are entered.
Could you please advise whether this issue can be resolved, or whether any additional configuration is required?
Hi XiZheng,
I am sending you some AS6 help links that might just solve your problem
There are some additional settings required in Automation Studio and mapp 6.x compared to mapp 5.x, but since you’re using mapp 5.16 I can’t think of any “gotchas”.
How are you “logging in”? Is this through a mappView HMI or are you using the MpUserXLogin block to log in through the application?
Are your credentials stored locally in Automation Studio’s User-Role system or are they in an Active Directory server?
Are you getting any errors in the Logger when you try to authenticate?
