Hello everyone, having decent experience with modbus tcp and b&r plcs i would like to attempt a modbus rtu connection to a slave module .
With tcp it is relatively simple to use the Ethernet interface and configure a slave or master connection.
Can anyone assist in also using a simple method to use modbus rtu and achieve this simple method ie read write coils,registers and so on
there’s a library called DRV_mbus for master or slave functionality, some more Infos can be found here:
Thank you will try out this library!
