Need ProSYS software for B&R M264
Good Day
I understand this was on a previous thread that got closed but I need the ProSYS software to communicate to a B&R M264 I 1st tried PG2000 but it keeps becoming non responsive when I push connect and research showed me I need something older.
@oliver_D please can you send me the software so I can communicate with the plc
Thank you for you help
justin
Good day @Jduchiha
I will send you a private message containing ProSys
The software is free of charge BUT you will need an online adapter which serves as dongle for the software and as converter between parallel port or serial port of your PC to the TTY interface of the PLC
This adapters are no longer available - so I hope you already own one as otherwise you cannot get online to the PLC
best regards
Oliver
best regards
would a made cable that runs from the 25pin connector to the db9 pin connector to an rs232 communication device to my pc not work?
because the pdf looks like it has the wiring for a communication cable considering its the transceiver and receiver pins with the ground.
This will not work. As mentioned there is an adapter needed which serves as dongle
Without this you will not be able to go online
BRKAOL5-0
BRADOL-0
This were the order numbers back in this days but as mentioned they are obsolete since almost 20 years now
Sorry for the bad news
best regards
Oliver
Oliver,
I have a customer in need of a program download to a new PLC. Would it be possible for you to send me the PROSYS software as well?
Thanks,
Dan
Hello @djeffs
sure - I will send it to you. Nevertheless Prosys is only part of the things you need. More “critical” is the online adapter you need
Please see the messages above
best regards
Oliver
Thank you so much for sending that over. I saw the above information, do I need both of the adapters that you listed?
You are welcome !
Regarding the online adapter you only need one.
BRKAOL5-0 → parallel port adapter
BRADOL-0 → serial port adapter
Depends what your PC offers but I need to “warn” you as well as this adapters are obsolete and no longer orderable
Sometimes you find some on the internet for sale but this is nothing I could guarantee
best regards
Oliver
