OPC UA Pointer FB Variables Tree Does Not Open
Previously, I could open and use pointer fb variables one by one thanks to the plus symbol.
But I can’t use it now. What would be the reason ?
AS : AS 4.12.5.95
MappView : 5.24.1
Thank you!
Hi, this is known bug solved in AS4.12.06 SP
Thanks Jaroslav, has AS4.12.06 SP been released ? Because I couldn’t see it on the site.
Not yet. There is not official release date. But workaround should be that you modify the OPC UA properties on the original PV where the pointer is pointing to.
