couldn’t find any fix to this error in manual, can somebody help me? running at Wintersteiger machine, and we can’t use it i think because of that
The solid red LED indicates that your PLC is in service mode.
Please see this post for more information about service mode and collecting diagnostics.
Hi @steamdreytix Dmytro,
It looks like you got a good recommendation from Andrew, and it has been a couple of weeks since the last activity on this post. If the answers helped you with your question, can you help the next person with the same question by marking the solution on the information which helped you the most. If you still have open questions on this topic, can you provide an update?
