1.A number of PC2200s have been found to be dead one after another from December to January (more than 4 have been confirmed to have occurred so far), and recovered after a power failure and reboot;
2.At the beginning of the project, the ambient temperature at the site was as low as -5 degrees Celsius, which was initially thought to be a temperature problem. However, when the air conditioner was subsequently put into operation, the problem still occurred when the ambient temperature was above 10 degrees;
3. The subsequent suspicion may be caused by the insufficient capacity of the switching power supply that powers the PC2200, and the switching power supply was replaced with a 100W power supply, but the above situation occurred again;
The Windows log image is below:
Why is this and what can be done about it?
Common Causes of volmgr Errors:
Event ID 46 – Crash Dump Initialization Failure
- The system was unable to initialize the crash dump file.
- Causes:
- Page file is too small or disabled.
- Insufficient disk space.
- Corrupt system files.
- Issues with storage drivers.
Event ID 6008 in the Windows Event Log indicates an unexpected system shutdown, meaning Windows did not shut down properly. This can be caused by power failures, hardware issues, or software crashes.
->PPC2200 has a CFAST card as storage, so I would recommend replacing the CFAST card and analyzing the used one using a SMART tool. Since the issue is present on multiple devices, please use the standard B&R support channel. Topic is marked as a solved by moderation team.
