Possibility of changing nominal motor data ACOPOS P66 Inverter at runtime
Introduction:
I use an ACOPOS P66 with Powerlink in my machines. I take Motion Configuration with the mapp object of type axis mappAxis as the function model for the ACOPOS P66 inverters.
Question:
Is there a way to change the nominal motor data cyclically at runtime?
Thank you very much😊.
Johannes
i think there is no access via the MC_BR_ProcessParam or MC_BR_ProcessConfig to this values.
The values should be accessible via the asynchron Powerlink Registers.
PLK-Register P66
To write these Registers you can use this Library
AsEpl - SDO Write
I never did it that way, just give it a try.
Hello Michael,
Thank you very much Michael.
I’ll give it a try and report back here in the community.
Johannes
