Hi Community!
I see few questions from few customers about the same topic: “For the new machine, with “new“ B&R CPU should I use PVI or OPC UA connection?“
Hi Community!
If possible and there are no technical difficulties, go always OPC UA way. ![]()
pros OPC UA:
pros PVI:
use OPC UA whenever it is possible.
I’m very interesting about your opinion too @hobi72 @alexander.hefner …hehe
Hi …
As other already said … if you have the possibility, I would go with OPC-UA.
CHH
Hi @valerio.manenti,
my opinion about it is very clear:
if you have the possibility, you should always use OPC UA as first choice (reasons: see @christoph.hilchenbac post
there still might be (technical) reasons to use PVI (ANSL) instead of OPC UA today. But I would always recommend even then to analyse the requirements case by case, and also to take into consideration using a “mixture” of OPC UA and PVI/ANSL (which sounds crazy in the first moment, but would maybe make a future transformation to “OPC UA only” less difficult).
BG Alex
