PLC - Non-Industrial PC Communication
Good morning everyone,
I need to exchange read and write information from a B&R PLC (specifically a C80) with a non-industrial pc running windows 10. Possible alternatives and solutions? I was thinking about using OPC-UA since we already use the protocol for mappview but I would need some suggestions on how to implement the possible the client/server on windows.
I am available to provide additional information.
Thank you
Hi Nicolo @nrampinelli01 ,
This is more a question of which data you want to exchange with the controller, which programming languages you want to use on the PC or whether you want to use ready-made packages (e.g. SCADA).
OPC-UA is the current way to access controller variables, for example, and Python is probably the easiest way to implement it.
Find a simple example here
Hi @nrampinelli01,
Did you end up using Christoph’s suggestion, or pick a different method? Please let us know what worked for you!
Hi, sorry for the late reply.
we have discontinued the above activity at the moment.
I will get back to you with feedback as soon as we resume it.
Thank you
Thanks for letting us know! I’ll mark Christoph’s response as the solution for now, but feel free to post again if you have an update.
