RELEASE 2026: Support of BOOL ProcessData cyclic exchange for B&R IO-Link Masters
Hello B&R Community,
We are pleased to announce the release of new hardware upgrades for B&R IO-Link Masters.
With these upgrades, the data type BOOL[8] is now also available for input and output process data. This means that the eight bits are stored as individual Boolean values directly in the I/O mapping.
This makes handling bit-based process data easier and more transparent, as each bit can now be accessed and used as a separate Boolean signal in the application.
The following hardware upgrades include this new functionality:
X20DS438A         2.5.0.0
X20cDS438A        2.5.0.0
X67DS438A         2.3.0.0
X20DS838A         1.1.0.0
X67DS838A.L12     1.2.0.0
X67DS838B.L12     1.2.0.0
X90DSI00.04-00    1.4.0.0
After installing the corresponding hardware upgrade, BOOL[8] can be selected for supported input and output process data and will be shown as eight individual Boolean values in the I/O mapping.
The configuration can be scaled up to 8 BOOL[8] values per direction, as with other supported data types.
This addresses some previous pain points, such as the one described here:
Enjoy the new feature!
Filipe Costa
thanks for sharing :slight_smile:
Thank you for sharing this helpful improvement. We already use it for valve terminals successfully.
Here are two key features/capabilities we are still heavily missing in practice:
1. PDO Multiplexing for Larger Output Data
We need support for PDO multiplexing to handle devices requiring more than 30 bytes of output data on a single module.
  • Current Limitation: At the moment, we can only connect a maximum of two of these signal lights per master: Balluff BNI00LM.
2. Flexible PDI Data Structuring
The current limitations around data types make mapping complex IO-Link devices difficult. Specifically, we need:
  • The ability to mix Octet Arrays and Boolean sections. This would allow direct mapping of real sensor signals (enabling forcing/diagnostic capabilities) alongside diagnostic data in bulk via octet arrays.
  • (or) Support for more than eight various data types to extract all data at the IO level. With the current 8-entry limit for mixed/various data types, it is impossible to properly model PDI structures like the one found on the Balluff BNI00KL:
PD IN (device → master), 12 bytes, Variant 1 / Profile 1
  • Byte 0: Pin 4 input state (bit n = Port n, Pin 4)
  • Byte 1: Pin 2 input state (bit n = Port n, Pin 2)
  • Byte 2: Supply Monitor (bit 7: Module Overload, bit 6: Overvoltage UA, bit 5: Overvoltage US2, bit 4: Overvoltage US1, bit 3: Output off, bit 2: UndervoltageUA, bit 1: Undervoltage US2, bit 0: Undervoltage US1)
  • Byte 3: Pin 1 Error (bit n = Port n)
  • Byte 4: Pin 4 Error (bit n = Port n)
  • Byte 5: Pin 2 Error (bit n = Port n)
  • Byte 6: Status flags (Extension Port Alarm, Module Overload Alarm, Device Temperature Alarm, Maintenance Required + reserved)
  • Bytes 7–10: Vibration Level RMS (FLOAT32 [mm/s])
  • Byte 11: Alarm flags (System Error, Temperature Alarm, Vibration Alarm + reserved)
PD OUT (master → device), 2 bytes
  • Byte 0: Pin 4 output state (bit n = Port n, Pin 4)
  • Byte 1: Pin 2 output state (bit n = Port n, Pin 2)
P.S. This device also supports daisy-chaining two units together, resulting in 24 bytes of PDI and 4 bytes of PDO per port. While the masters technically allow daisy-chaining them, the current IO-mapping configuration limitations force us to handle them strictly via octet arrays.
