Restoring a legacy machine using a B&R Provit 2000 IPC2001
@oliver_D I’m hoping you may be able to help with some very old B&R software.
I am restoring a legacy machine using a B&R Provit 2000 IPC2001 (5C2001.02) running MS-DOS. The original SRAM/FPROM configuration needs to be rebuilt, and I am trying to locate the genuine B&R DOS utilities rather than use substitute software.
The original package I am looking for is:
5S2001.01-090 — Provit 2000 Utilities IPC2001
According to the original B&R documentation, I specifically need:
  • BRSRAM.SYS
  • BRFPROM.SYS
  • BRIMAGE.SYS — v2.50 or newer
  • BRIMAGE.COM — v2.50 or newer
  • BRPCMCIA.SYS
  • BRCOMOFF.SYS
  • BRCMOS.COM
  • BRMODES.COM — v2.10 or newer
An original ZIP/archive or floppy image of 5S2001.01-090 would be ideal.
I would also be interested in either of these if the IPC2001 utility disk is unavailable:
5S0000.01-090 — HMI Drivers & Utilities CD
or
5S2000.01-090 — Provit 2000 Utilities IPC2000, provided it contains BRIMAGE.SYS and BRIMAGE.COM v2.50 or newer.
I already have the machine’s original application/runtime files and am specifically trying to recover the B&R low-level SRAM/FPROM/PCMCIA service utilities.
@oliver_D, if you have an archived copy of this software and could share it with me, I would greatly appreciate it.
Thank you.
Hello Richard @TBOT
I sent you a private message with the Provit Utilities
best rgeards
Oliver
Thats exactly what I needed, thank you very much. Have a wonderful day!
You are very welcome ! Have a nice day
