RS485 communication x20 series
@SvenG,
can you please check if you have the latest firmware and Automation runtime running?
If not, could you please update:
  • PLC firmware
  • PS firmware
  • Automation Runtime
Unfortunately I don’t have the same hardware, but I played around a bit and I had some issue where I’m not sure where it’s coming from. After updating firmwares and AR to the latest versions, I looked better at my test.
These are the versions I used, but als I said: it’s not exactly the same hardware, so maybe versions differ.
