Sceneviewer Files not showing up and PVI not working
Im trying to visualise the ACOPOStrak in Scene Viewer, but I can’t seem to generate the .SCN files.
I was able to do this in previous projects I made, but now when I start a new one it doesn’t generate. In my previous projects I changed my File Device name setting of my X20CP1685X to SvgData and I kept the Path standard (USER_PATH). The files then show up here: ‘C:\projects\ACOPOSACHT\Temp\Simulation\X20CP1686\X20CP1686X\USER’
In my current project I have applied the exact same File Device settings so the files should show up here: ‘C:\projects\XR4_TRAK\Temp\Simulation\XR4_TRAK\X20CP1686X\USER’. Unfortunately this directory is still empty…
Has anyone else encountered this issue before or knows what might be causing this issue?
Kind regards,
Milan Oude Nijeweme
The problem was that the configuration of the track wasn’t completely correct.
I connected a second trak, but didn’t configure it properly. Once I disconnected it, it generated the files :slight_smile:
