ACOPOStrak compact 180° curve HW-Upgrade and SW-Version
as you all probably know, mapp Motion V6.4.1 is the first official version which will support our ACOPOStrak compact 180° curve.
It is important to use the correct .hwx-file called AS6_HW_8F1I01.AA8C.xxxx-1.exe in order to have the system running.
Minimum version for usage of ES segment
  • mapp Motion>=6.4.1
  • AS6_HW_8F1I01.AA8C.xxxx-1
More and more, we’re facing problems in the field that customers are using the old and invalid .hwx-file (“AS6_HW_ACPtrak_180_seg_compact.exe”), which leads to an invalid state of the 180° compact curve. The only way to solve this problem is to reset to BSL via display. Attached is a word document which describes it step by step.
ACPtrak_reset_to_BSL_via_display.docx (48.3 KB)
AS6_HW_8F1I01.AA8C.xxxx-1.zip (484.6 KB)
Hi @florian.niederhofer, thanks for important info. I just copy content of your word document as a new article that is possible to find it using search function :slight_smile:
Thanks for sharing.
