Unable to boot into automation PC 3100
When trying to boot into the APC 3100 it is showing shell window and not showing any OS installed in the SSD.
Could be that you need to disable UEFI in BIOS if you want to use AR?!
I’m not sure but could be something like that…
Are you even trying to boot AR??? Or Windows / Linux?
I have tried with both legacy and UEFI it is not showing any OS detected.
Can we reinstall the OS into the APC again?
And what is AR? we are trying to get the windows?
AR is the B&R Automation Runtime, the realtime OS for the PLCs.
If you’re trying to boot into windows and there is no windows on the CFast card, you’ll have to install it. You should get in touch with your sales contact or your local office. The support there has options to help you.
Best regards.
