Unable to Watch C Variables in Debugger, but Structured Text (ST) Variables Are Visible
I have an application that contains both Structured Text (ST) code and C language code.
During debugging, I can successfully monitor variables declared in the Structured Text program through the watch window. However, variables declared in the C code are not visible or cannot be added to the watch window.
Please suggest how i can watch C variables in watch window !!
Regards
Holas
Hello Holas,
welcome to the Community.
You generally cannot watch raw C/C++ variables directly in the normal Watch window like ST variables. For C/C++ code, you can expose the C values via a process variable (PV) and watch that PV in the normal Watch window for example.
You could also use the Contextual Watch
Best regards, Thomas
Thank you Thomas , for valuable feedback.
