Hi Community,
I’m trying to use a relative path when creating a CF card. For this, I wanted to use the Offline Commissioning function in Runtime Utility Center.
However, it seems that only absolute paths are accepted—I can’t find a way to insert a relative path.
The reason I need a relative path is so I can share the instruction list with a colleague. Ideally, they should be able to use the .pil file straight out of the box without having to adjust paths.
Thanks in advance for your help!
Philipp
