Hi Community,
when set up connection to 12 VCs, as shown in the figure below, the first 10 VCs can get valid handles and no error occurred. But the last two report error 7180, which means ‘Error accessing from the resource’. How should i deal with the error or is there any workaround?
Many thanks in advance for your help.
Xiaowen
Hello @Xiaowen_Liu ,
The AS Help says that maximum number of VISAPI connections to different HMI applications is limited to 10 per target system. This applies equally to local HMI applications and terminal HMI applications.
Hello @patrik.simcik ,
i didn’t find the help information in AS 4.12, can you show me the Guid or location ID?
I found the mentioned info in the AS Help 6.0.2.113 (not AS4.12) - GUID: ‘b0cbe306-926a-480e-ada2-3dcb363c8391’
