Hello.
I am testing an HMI visualization program.
The product is the GPPT30.043F-20B model.
During the process of transferring the program, I encountered the following error. I have set the bitmaps to raw8bit, but the error message indicates that it is set to 32bit.
How can I change the settings so that raw8bit can be used?
Thanks.
it looks like that your project uses 32bit bitmaps, but the project ColorMode is set to 8bit.
Maybe not all of the bitmaps are set to 8bit, have you checked the the bitmaps named in the compiler error messages? I can’t see them in the screenshot.
