VNC - Visual Component
Hi
After a long period of work on a project without any problem, now I’m not any more able to open the HMI (dev with Visual Components 4.73.1) with VNC from my computer.
To explain better :
I use a PLC to test my project but now (again after a long period without problems) I cannot open the Visual Comp with VNC.
VNC open the window but I have the messe “Protocol Error: bad hextile data”
I tried to delete and create again the connection in vnc.
I also reinstall the complete project on the PLC with an offline project installation.
If I test my project on my computer with ARsim that works fine.
Have you some idea?
Christian
I found the solution.
I forget that I have change the ColorMode from 8Bit to 32Bit in the Visual Component Configuration.
Due this modification it was necessary to change (in VNC) the Quality image from Automatic to “Middle”
Christian
