Widgets are disable on another laptop
I had shared AS project to my team and found most of the widgets are not working. But this same project works in my laptop.
Hi, we need more info about what does it mean that “widgets are not working”. In topic description is mentioned that widgets are disabled, if this is so, then check role set in widget property permisionOperate.
Hi HNS, any update about this topic?
Due to inactivity closed as a unsolved.
Hi HNS, feel free to update us :slight_smile: I would be happy if you share with us possible solution.
No for this I have not checked yet solution or tried further more.
Once I found or try then i will surely update here
