X20CP3687X Onboard Storage and CF Card
Hello:
The X20CP3687X has an on-board 2GB storage, if I use the on-board storage for my system, can I also use a CF card as storage data at the same time?
as far as i know, you can only use one of them at a time, not both in parallel.
The help does only mention this seperate operation modi.
Programmspeicher auswählen
You can use the USB for transportable Storage.
Michael is correct. It’s not possible to use both CF/onboard storage at the same time.
Thanks for all the answers, very helpful.
