X90IF730.04-00 support for RS422
hello,
does the X90IF730.04-00 communication module support RS422?
i do not see it in the datasheet but in the AS module configuration it is possible to select it.
thank you.
The software would support RS422 but unfortunately the symetric pins are not wired to the CMC connector.
So in short: not possible and it is not mentioned in the technical specification.
