It happen when i compile a block or doing a build or even a download.
Reboot the runtime is the only solution i have now but on one of the APROL concerning, it happen every day.
From this screenshot, it is hard to tell where the issue is.
However, I can tell that the file ‘syslog’ is missing from the file path /home/aprolsys/APROL/logfifos.
Can you please check if it is really missing, and if it exists, what permissions the file has?
Did you configure and activate Chronoplex in AprolConfig?
Thanks Vincent, please update us when you find the cause of the problem.
Normally 2 support groups don’t work on the same issue so I think on Community side we wait feedback from your local support.
Hello Vincent, thanks for the answer . Does it mean you must reinstall the Aprol Software or “only” delete and restore CC-Account engin in AprolConfig?
Thanks for your answer.
/var/opt/aprol/APROL/logfifos is not standard, or maybe in APROL 4.4, i’m still in 4.2-06 for now, waiting AS 6 before migration.
Mine is inside /home/aprolsys/APROL/logfifos
All rights are good compared to another good running system but 660 instead of 770.
Found indeed many errors in ChronoPlex.err : ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near DbMgr ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near DlMgr ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near DlMgr ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Dsgn ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Dsgn ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near IdSys ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near IdSys ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Lib ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Lib ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near LoginServer ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near LoginServer ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Offline ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Offline ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near OpMgr ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near OpMgr ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near Prj ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near id ChronoPlex: ChronoLog: target file /home/aprolsys/APROL_DATA/chronolog/syslog.clc (24.07.2026 06:07:12): parse error in input file - at line 2377 near ActivateObj
I will try chmod 770 and restorecon, i still have one APROL with these issue on 4.2-06
