Hello, I am a novice engineer. When I installed Aprol software version 4.4 and tried to build and test it, I got various errors. Can you help me? Or, what manual should I refer to?
Hello @sangmin_yoon,
Did you keep the default password for SqlSystemOperator, or set up your own?
- Please check if the same passwords are used in OperatorManager and Project properties/Authentication for this operator name.
- What security mode did you set in the TLS configuration?
Hello! @tomas.miculka
- I had set all the administrator passwords the same. And now I have changed them all.
- I didn’t know about the TLS setting and did it late.
Thanks to you, I was able to solve the problem. Thank you!!!
