Hello everyone,
I can add or edit URS properties using the FUB ArUserSetProperty.
Is there also a way to remove a property? Setting PropertyValue to '' doesn’t work.
Does anyone have any ideas?
Hello everyone,
Hello Simon,
i have currently not found a function to delete only a property.
But you can overwrite it with '' so it is empty.
What is the negative effect of having an empty Property?
I think currently you can only delete the property by deleting the whole user.
ArUserDelete
Hi Michael,
I used ArUserGetProperty() to check whether the property exists. ErrorID <> arUSER_ERR_DOES_NOT_EXIST
I’m now going to write an empty value and check if PropertyValue matches the required value.
That works for now. Maybe someone else has an idea. But thanks a lot for your input!
