Automation Studio Hardware List Export
I am a new user of the Automation Studio software and I was wondering if there was a method for exporting the hardware list in Excel or some other text based format.
Hi Edgar,
Relative to the installation folder of Automation Studio, you can check this directory “AS\Hardware\Modules” in there you will found 1 folder per hardware module. I don’t know if they are all here, but for sure a bunch are in this directory.
Florent
I haven’t done it yet in AS 6.0, but in AS 4.x it was possible in the physical view to select all (Ctrl+A), copy (Ctrl+C), and then paste in to (Ctrl+V) into an open Excel document and you would have all the info from the physical view (and extra, because it would contain all of the hidden terminal blocks and base modules and motor cables (assumed).
if you are in search of a combined “ordering list” were you would get the same modules added to an amount, such functionality does not exist as far as i know.
The way with the copy paste to excel is a nice feature but you will have the same list as you can see it in Automation Studio.
If the format of the textfile must not be Excel you could use the Export for ECAD. The only supported Format is for ePlan P8, it looks like an xml File.
