I’m new to B&R mapp view application.
I tried to communicate between S7-1200 and Mapp view using OPC-UA but communication was not established. I used an ethernet cable between the PC and PLC.
Is there any other way to communicate between S7-1200 and Mapp view?
Does this need any OPC-UA software like the Kepware OPC server?
There are some limitations you need to be aware of.
Please take a look at the documentation here Siemens OpcUa lmitations
Can you share how you set up the communication between mappView and the S7?
We also have a Technology Solution called CYV that could help you with the communication configuration since the address format Siemens is using is a bit odd and you can’t browse external OpceUa servers.
