I have problem with C50 terminal after update AS to 6.7.
I run it before without problem (AR6.7.5 and the mappView is still same). I also try AR6.7.6. But now it’s show only “Waiting for configuration…”. Any tips what change or where to find some problem?
Hi @NovotnyJ ,
I faced the same issue when I did some internal tests with my colleague with C80 last week. R&D is working on the fix.
The following combinations still work:
AS 6.7.0 + AR 6.6.2
AS 6.5.3 + AR 6.7.6
Problem description:
The C80 / C50 panels do not show any visualization (VNC, mapp View) anymore when you use the combination of AS 6.7.0 + AR 6.7.6.
The C80 / C50 panels stays in the screen Waiting for configuration.
you know Jan on the Community we have to follow this guideline:
“If you found a bug in an official B&R software, please report this directly to your local B&R Support team. The B&R Community is not the official channel for bug reporting. The exception is for bugs related open-source developments within the community itself. The same restriction applies for quality topics.”
Our Support has more information about release date for the fix.
