Change Brightness of the screen in mappview
Hello together,
is there any possibility to change the brightness like in VC4 (there you need to use visapi)
i found no widget to take care about that issue
Not within Mapp view directly.
If the client is running the Terminal OS, I think it can be done via OPC UA ( B&R Online Help) or the AsRfbExt library for B&R VNC Client applications( B&R Online Help).
Agree with @Matt_Buck, what hw do you use for your mappView client?
Thank you for the advice. I will try it
Hello Jaroslav
It a c80 panel
For C80 you can use library AsScreen.
Thank you for your help.
is it working for you?
yes, this is enough for my issue. Thank you
