If an APC has an X20 Ethernet/IP slave equipped, can the process variables for X20 Ethernet/IP slave be mapped to variables while the APC is running? Will a transfer and reboot be required? Is there any way to change the slave I/O mapping without causing the APC to stop?
Hello Garrett,
yes, it should be possible. Please take a look at this library: AsIOMMan
Regards
Hi @Garrett_Higgins , any other questions, or your question is solved?
It is solved, thank you!
Thanks for update. In general if your question is answered, issue solved, etc. it is always good to mark discussion as a solved
Thanks a lot.
