Clarification on Secure FTPS Configuration in Automation Studio (4PPC70)
I am currently configuring FTPS communication in Automation Studio for a 4PPC70 PLC and would like to confirm whether my approach follows recommended security practices.
Configuration steps performed:
  1. Created a certificate under Access and Security β†’ Certificate Store (own certificate with auto-generated private key).
  2. Enabled secure communication in PLC configuration:
    • Online Parameters β†’ Protocol: Secure (SSL/TLS)
    • FTP Server: ON (FTPS)
    • Web Server: ON (HTTPS)
    • OPC UA: Enabled
  3. Downloaded the configuration to the PLC.
  4. Connected using WinSCP with:
    • Protocol: FTP
    • Encryption: Explicit TLS/SSL
    • Encountered error: β€œSSL3 alert write fatal: Protocol version”
  5. Resolved the issue by setting minimum TLS version to TLS 1.0 in client settings.
After this change, I am able to access PLC files successfully.
However, I would like to understand:
  • Is this configuration considered secure?
  • What are the recommended best practices for FTPS configuration in Automation Studio?
  • Is using TLS 1.0 acceptable in this case, or should it be avoided?
  • Are there additional security measures I should implement?
  • What would be the most secure approach for configuring FTPS or alternative file transfer methods in this context?
Any guidance on achieving a more secure setup would be appreciated.
Thank you :smiley: .
Hi Sandeep, I would recommend checking the following page for general guidance on Automation Runtime cybersecurity: B&R Online Help
Specifically, here are some considerations and best practices regarding FTPS:
Please let us know if you still have specific questions after consulting this page.
Additionally, I want to inform you that we have an Online Course (paid) that discusses System Hardening in AS 4 and AS 6, here is the link in case you would like to learn more information: Cyber Security basics and system hardening with Automation Studio [SOC990.1] | B&R Industrial Automation
