The request was aborted: Could not create SSL/TLS secure channel
Hello Professionals,
I have installed automation studio ver.4.2.10.53 for Windows7/64Bit.
We have received your license key for automation studio, after entering the license key, the system displays the message below:
Quote: “The request was aborted: Could not create SSL/TLS secure channel”
And I have installed Technology Guarding 1.3.1.1 to activate license through online, it failed to communicate B&R license server.
We require your urgent support to obtain information from PLC fieldbus CPU X20XC0292 with Profibus DP V1(X20IF1061-1, X20IF1063-1) master and slave interface.
Online registration is not available anymore for AS <= 4.5 due to cybersecurity reasons. You can use the offline licensing instead:
br-automation.com/es-es/servicio/licencia-offline-de-automation-studio/
for support and service you run AS 4.2 in trial mode.
Hi Mr.Javier,
Thank you for your prompt reply and assistance. The license is now active, and Automation Studio is functioning properly.
BR.
