Debug editor/possibilities in Automation studio 4.9
Hello, I’m new to the B&R PLC code development area, I’ve always programmed in Siemens and AB, I’m having difficulty making a quick diagnosis of the logic.
Is there any function that I can enable or any tips for having a monitor like the Siemens editor, as shown below
Where can I see when the condition is being satisfied or the line is validated?
If the code was compiled and transfered to the Target (PLC or ARsim) and you have a online connection you can use the Monitor-Mode or the Watch-Window.
Monitor-Mode
In the Icon-Bar there is a “magnifying glass”-Icon which enables the monitoring mode. It supports Mouse-Over tooltips in the code and a watch list on the right side were you can insert Variables to see thair values.
Watch-Window
You can right-klick on the blue Task icon and select open->watch. There you can insert the variables and get thair values.
Hi, there are more option how to monitor your code. There is even training module for that. For your use case I would use line coverage B&R Online Help
