Detecting if the CPU has been cold restarted
Wondering if there is any way to detect if a cold restart has been done. I need to run some code initially if this is the case.
Originally done this in the INIT of the program but this is also executed during a warm restart also.
should be possible using the function RTinfo, output .init_reason
Best regards.
Many thanks will use that then.
