DTM error when compiling, IDtm::Config
Hi all!
Does anybody knows a solution - or a direction where to search - for this error when compiling a project:
An error occured during FDT/DTM netX build. (The DTM refused the call to IDtm::Config.)
Mathias
Hello Mathias,
Kindly install the latest DTM catalog first. Downloads | B&R Industrial Automation
Hi @Mathias, what is status of your topic? can you update us?
Hi Jaroslav,
if we are installing new DTM lib 2.1.1.2 then following occurs.
Hello Mathias,
I have previously examined a similar case. At that time, it proved helpful to remove the interface card from the hardware tree within the project and reinsert it.
@Mathias Another thing to try would be to uninstall all DTM / Hilscher software and try reinstalling as administrator (right-click > Run as Administrator on the DTM installer executable). After installing, open Automation Studio as administrator as well to make sure the DTM catalog updates properly.
@rafael.laury Same error, unfortunately not working.
Hi @Mathias, please get in contact with the support of your local B&R office, and when you investigate the solution, please share it with us.
