How to I change Video source?
Hi BnR, I would like to create a simple program to read any .mp4 video files placed into “Folder A”. The issue I am currently facing is I can’t change the source of the video to go outside of the “mappView/Resources” folder.
Is there any particular solution to this?
Thanks for your help.
Would be great if there is a sample coding of how to change the video source too.
Hey Noah,
check out this help entry:
Zugriff auf externe Ressourcen über File Devices
260f42a3-62ea-412c-b6a3-4515a5611080
So you should be able to use any FileDevice you created on the PLC.
If the URL path begins with the keyword /FileDevice:, then the contents will be read from the specified file device.
And in order to change it during runtime, you’ll have to create a binding for the src property. I guess you know it, but in the screenshot it’s not connected :slight_smile:
Marcel
