If you want different syntax highlighting you can adjust it to your liking via Tools > Options > Colors/Fonts. Here you can also adjust other settings like the background color. For programming with text you need to edit in the category “Text editors”.
The settings are stored in the Editor.set file.
If you want to share your settings with others:
- Go to
C:\Users\[user]\AppData\Roaming\BR\AS412 - Copy the
Editor.setfile and send it to your coworkers
Or if you want to also use the ones from your coworker:
- Go to
C:\Users\[user]\AppData\Roaming\BR\AS412 - Rename your
Editor.settoEditor_OLD.set - Paste the
Editor.setfile from your coworker
If you accidentally loose your original Editor.set file Boaz Stolk uploaded a backup on GitHub here for our convenience ![]()
Related Post:
Dark Theme for Automation Studio
