Hypervisor failed boot after installation
Hi, I am using an APC3100 (5APC3100.KBU1-000) and I tried to boot Hypervisor but without success.
While booting initialy after the setup, the system comes to a halt while performing the second boot.
After conducting a power cycle the Hypervisor boot failes even earlier. Seems like data got corrupted.
I am receiving the following outputs.
Due to beeing new I am unable to provide the install_log.txt for further reference.
What I did as of now is:
Upgrading BIOS from a1.25 to a1.45
Upgrading MTCX from 4.25 to 4.27
Updating AS and ARemb: F4.12.5 and F4.93.1
Enabled the RTOS and the Hypervisor in the BIOS setup Menue.
Updated the HW Upgrade to 2.2.7.0
Replaced the AHCI Driver.
Configured the project as per suggestion in the Guide.
Installed the GPOS Driver beforehand.
I installed Hypervisor multiple times via USB-Stick through the Boot Menue.
And checked, that the USB-Stick was not listed as the first item in the Boot Menue.
Also I installed Hypervisor via Windows as per suggestions from another post.
I also performed the installation on an APC2200 without any booting issues.
Adding the initial booting sequence output.
The mentioned log.txt should be on the usb memory stick. Can you share it?
It should give more information about what went wrong.
Hi Philipp , Is this problem solved? just asking because second topic created by you APC2200 BIOS clock issue
Hello @kovarj, unfortunately not. I am working with an APC3100 and an APC2200.
Hypervisor works for the APC2200 but not the APC3100 as of now.
ok can you provide log.txt from usb memory stick?
I would love to, but as a new Community Forum user I am unable to upload it at the moment. I will upload it, when this restriction expires.
ok but you can open text file and copy content? :slight_smile: I also increased your trust level, because I trust you :slight_smile:
Wed Nov  6 09:38:04 UTC 2024 info : B&R Hypervisor install / uninstall script started.
Wed Nov  6 09:38:04 UTC 2024 info : AR version: M4.93
Wed Nov  6 09:38:04 UTC 2024 info : SILENT_INSTALL=0
Wed Nov  6 09:38:04 UTC 2024 info : MIN_FREE_SPACE_IN_MB=0
Wed Nov  6 09:38:04 UTC 2024 info : DISK_NUMBER=
Wed Nov  6 09:38:04 UTC 2024 info : system info:
Wed Nov  6 09:38:04 UTC 2024 info : OEM string 1: 5APC3100.KBU1-C00
Wed Nov  6 09:38:04 UTC 2024 info : OEM string 2: 5ACCLI02.SD40-000
Wed Nov  6 09:38:04 UTC 2024 info : OEM string 3:
Wed Nov  6 09:38:04 UTC 2024 info : OEM string 4:
Wed Nov  6 09:38:04 UTC 2024 info : OEM string 5:
Wed Nov  6 09:38:04 UTC 2024 info : BIOS: a1.45 05/17/2024 Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 09:38:04 UTC 2024 info : system: APC3100 a1.45 / V4.27 F0BD0169495 03000200-0400-0500-0006-0f0bd0169495 Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 09:38:04 UTC 2024 info : baseboard: APC3100 5APC3100.KBU1-C00 F0BD0169495 APC3100 Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 09:38:04 UTC 2024 info : chassis: 5APC3100.KBU1-C00 F0BD0169495 Desktop Chassis Asset Tag Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 09:38:04 UTC 2024 info : processor: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz Core i3 2400 MHz Intel(R) Corporation
Wed Nov  6 09:38:04 UTC 2024 log  : ethernet:
Wed Nov  6 09:38:04 UTC 2024 log  :     enp0s31f6 Link encap:Ethernet  HWaddr 00:60:65:5E:01:66
Wed Nov  6 09:38:04 UTC 2024 log  :               UP BROADCAST MULTICAST  MTU:1500  Metric:1
Wed Nov  6 09:38:04 UTC 2024 log  :               RX packets:0 errors:0 dropped:0 overruns:0 frame:0
Wed Nov  6 09:38:04 UTC 2024 log  :               TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
Wed Nov  6 09:38:04 UTC 2024 log  :               collisions:0 txqueuelen:1000
Wed Nov  6 09:38:04 UTC 2024 log  :               RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
Wed Nov  6 09:38:04 UTC 2024 log  :               Interrupt:16 Memory:b1100000-b1120000
Wed Nov  6 09:38:04 UTC 2024 log  :     enp1s0    Link encap:Ethernet  HWaddr 00:60:65:5E:01:67
Wed Nov  6 09:38:04 UTC 2024 log  :               Memory:b1000000-b107ffff
Wed Nov  6 09:38:04 UTC 2024 log  :     lo        Link encap:Local Loopback
Wed Nov  6 09:38:04 UTC 2024 log  :               inet addr:127.0.0.1  Mask:255.0.0.0
Wed Nov  6 09:38:04 UTC 2024 log  :               UP LOOPBACK RUNNING  MTU:65536  Metric:1
Wed Nov  6 09:38:04 UTC 2024 log  : drives:
Wed Nov  6 09:38:04 UTC 2024 log  :     Model: ATA SFCA128GH2AD4TO- (scsi)
Wed Nov  6 09:38:04 UTC 2024 log  :     Disk /dev/sda: 128GB
Wed Nov  6 09:38:04 UTC 2024 log  :     Sector size (logical/physical): 512B/512B
Wed Nov  6 09:38:04 UTC 2024 log  :     Partition Table: gpt
Wed Nov  6 09:38:04 UTC 2024 log  :     Disk Flags:
Wed Nov  6 09:38:04 UTC 2024 log  :     Number  Start   End     Size    File system  Name                          Flags
Wed Nov  6 09:38:04 UTC 2024 log  :      1      1049kB  274MB   273MB   fat32        EFI system partition          boot, esp
Wed Nov  6 09:38:04 UTC 2024 log  :      2      274MB   290MB   16.8MB               Microsoft reserved partition  msftres
Wed Nov  6 09:38:04 UTC 2024 log  :      3      290MB   75.6GB  75.3GB  ntfs         Basic data partition          msftdata
Wed Nov  6 09:38:04 UTC 2024 log  :      4      75.6GB  126GB   50.3GB  ntfs         Basic data partition          msftdata
Wed Nov  6 09:38:04 UTC 2024 log  :     Model: SanDisk Cruzer Blade (scsi)
Wed Nov  6 09:38:04 UTC 2024 log  :     Disk /dev/sdb: 16.0GB
Wed Nov  6 09:38:04 UTC 2024 log  :     Partition Table: msdos
Wed Nov  6 09:38:04 UTC 2024 log  :     Number  Start   End     Size    Type     File system  Flags
Wed Nov  6 09:38:04 UTC 2024 log  :      1      64.5kB  16.0GB  16.0GB  primary  fat32        boot
Wed Nov  6 09:38:04 UTC 2024 log  :     Model: Samsung Portable SSD T5 (scsi)
Wed Nov  6 09:38:04 UTC 2024 log  :     Disk /dev/sdc: 1000GB
Wed Nov  6 09:38:04 UTC 2024 log  :      1      1049kB  1000GB  1000GB  primary
Wed Nov  6 09:38:04 UTC 2024 func : getMinPartitionSizes()
Wed Nov  6 09:38:04 UTC 2024 func : _getPipConfig(pipConfig)
Wed Nov  6 09:38:04 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,67108864)
Wed Nov  6 09:38:04 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,90292124)
Wed Nov  6 09:38:04 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,11592668)
Wed Nov  6 09:38:04 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,10485760)
Wed Nov  6 09:38:04 UTC 2024 log  : 255MB minimum AR disk size
Wed Nov  6 09:38:04 UTC 2024 log  : 173MB needed project space
Wed Nov  6 09:38:04 UTC 2024 log  : 255MB minimum CFast size
Wed Nov  6 09:38:04 UTC 2024 log  : UEFI GPOS detected
Wed Nov  6 09:38:04 UTC 2024 log  : information of device /dev/sda updated:
Wed Nov  6 09:38:05 UTC 2024 log  :     Model: ATA SFCA128GH2AD4TO- (scsi)
Wed Nov  6 09:38:05 UTC 2024 log  :     Disk /dev/sda: 250069680s
Wed Nov  6 09:38:05 UTC 2024 log  :     Sector size (logical/physical): 512B/512B
Wed Nov  6 09:38:05 UTC 2024 log  :     Partition Table: gpt
Wed Nov  6 09:38:05 UTC 2024 log  :     Disk Flags:
Wed Nov  6 09:38:05 UTC 2024 log  :     Number  Start       End         Size        File system  Name                          Flags
Wed Nov  6 09:38:05 UTC 2024 log  :             34s         2047s       2014s       Free Space
Wed Nov  6 09:38:05 UTC 2024 log  :      1      2048s       534527s     532480s     fat32        EFI system partition          boot, esp
Wed Nov  6 09:38:05 UTC 2024 log  :      2      534528s     567295s     32768s                   Microsoft reserved partition  msftres
Wed Nov  6 09:38:05 UTC 2024 log  :      3      567296s     147668991s  147101696s  ntfs         Basic data partition          msftdata
Wed Nov  6 09:38:05 UTC 2024 log  :      4      147668992s  245872639s  98203648s   ntfs         Basic data partition          msftdata
Wed Nov  6 09:38:05 UTC 2024 log  :             245872640s  250069646s  4197007s    Free Space
Wed Nov  6 09:38:05 UTC 2024 log  : information of device /dev/sdb updated:
Wed Nov  6 09:38:05 UTC 2024 log  :     Model: SanDisk Cruzer Blade (scsi)
Wed Nov  6 09:38:05 UTC 2024 log  :     Disk /dev/sdb: 31260672s
Wed Nov  6 09:38:05 UTC 2024 log  :     Partition Table: msdos
Wed Nov  6 09:38:05 UTC 2024 log  :     Number  Start      End        Size       Type     File system  Flags
Wed Nov  6 09:38:05 UTC 2024 log  :             63s        125s       63s                 Free Space
Wed Nov  6 09:38:05 UTC 2024 log  :      1      126s       31246424s  31246299s  primary  fat32        boot
Wed Nov  6 09:38:05 UTC 2024 log  :             31246425s  31260671s  14247s              Free Space
Wed Nov  6 09:38:05 UTC 2024 log  : information of device /dev/sdc updated:
Wed Nov  6 09:38:05 UTC 2024 log  :     Model: Samsung Portable SSD T5 (scsi)
Wed Nov  6 09:38:05 UTC 2024 log  :     Disk /dev/sdc: 1953525168s
Wed Nov  6 09:38:05 UTC 2024 log  :             2s           2047s        2046s                 Free Space
Wed Nov  6 09:38:05 UTC 2024 log  :      1      2048s        1953522112s  1953520065s  primary
Wed Nov  6 09:38:05 UTC 2024 log  :             1953522113s  1953525167s  3055s                 Free Space
Wed Nov  6 09:38:09 UTC 2024 call : mkdir -p /mnt/part1 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:09 UTC 2024 call : mount /dev/sdc1 /mnt/part1 (/root/scripts/helper.sh:145)
mount: /mnt/part1: unknown filesystem type 'exfat'.
Wed Nov  6 09:38:09 UTC 2024 call : ntfsfix /dev/sdc1 (/root/scripts/helper.sh:156)
Mounting volume... NTFS signature is missing.
FAILED
Attempting to correct errors... NTFS signature is missing.
FAILED
Failed to startup volume: Invalid argument
Trying the alternate boot sector
Unrecoverable error
Volume is corrupt. You should run chkdsk.
Wed Nov  6 09:38:09 UTC 2024 call : mount -t ntfs-3g /dev/sdc1 /mnt/part1 (/root/scripts/helper.sh:157)
Failed to mount '/dev/sdc1': Invalid argument
The device '/dev/sdc1' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
Wed Nov  6 09:38:09 UTC 2024 log  : device and partition information:
Wed Nov  6 09:38:09 UTC 2024 log  : /dev/sda1, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 09:38:09 UTC 2024 log  :     fat32, primary, 273, 0, 1.05MB, 274MB, EFI, boot, esp,
Wed Nov  6 09:38:09 UTC 2024 log  : /dev/sda2, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 09:38:09 UTC 2024 log  :     unknown, , 16.8, 0, 274MB, 290MB, Microsoft, msftres,
Wed Nov  6 09:38:09 UTC 2024 log  : /dev/sda3, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 09:38:09 UTC 2024 log  :     ntfs, , 75316, 0, 290MB, 75607MB, Basic, msftdata,
Wed Nov  6 09:38:09 UTC 2024 log  : /dev/sda4, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 09:38:09 UTC 2024 log  :     ntfs, , 50280, 0, 75607MB, 125887MB, Basic, msftdata,
Wed Nov  6 09:38:09 UTC 2024 log  : /dev/sda, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 09:38:09 UTC 2024 log  :     Free, , 2149, 0, 125887MB, 128036MB, unallocated, ,
Wed Nov  6 09:38:09 UTC 2024 log  : /dev/sdc1, 2: 1000GB, 512, 512, msdos, Samsung Portable SSD T5, , -, Windows
Wed Nov  6 09:38:09 UTC 2024 log  :     , , 1000202, 0, 1.05MB, 1000203MB, untitled, ,
Wed Nov  6 09:38:09 UTC 2024 func : _createUefiARembInstallationCandidates()
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,free)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,free)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,free)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,free)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,free)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,5,free)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,ARinst)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,ARinst)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,ARinst)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,ARinst)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,ARinst)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,5,ARinst)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,all)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,all)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,all)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,all)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,all)
Wed Nov  6 09:38:09 UTC 2024 func : _getUefiPartitionString(candPartString,activated,5,all)
Wed Nov  6 09:38:09 UTC 2024 func : getEspPartition(espDev, espPart)
Wed Nov  6 09:38:09 UTC 2024 func : hasUninstallCfgFile(newUefiUninstallation)
Wed Nov  6 09:38:09 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Wed Nov  6 09:38:09 UTC 2024 call : mkdir -p /mnt/part2 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:09 UTC 2024 call : mount /dev/sda1 /mnt/part2 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:09 UTC 2024 call : umount /mnt/part2 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:09 UTC 2024 call : rmdir /mnt/part2 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:15 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 0%
Wed Nov  6 09:38:16 UTC 2024 info : B&R Hypervisor efiPartMarker_ndr7W3NhJy installation started.
Wed Nov  6 09:38:16 UTC 2024 func : logWriteInitUninstallFile()
Wed Nov  6 09:38:16 UTC 2024 func : getEspPartition(espDev, espPart)
Wed Nov  6 09:38:16 UTC 2024 log  : ESP: /dev/sda 1
Wed Nov  6 09:38:16 UTC 2024 call : mkdir -p /mnt/part3 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:16 UTC 2024 call : mount /dev/sda1 /mnt/part3 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:16 UTC 2024 log  : emptying uninstallation file /mnt/part3/uninstall.cfg
Wed Nov  6 09:38:16 UTC 2024 call : umount /mnt/part3 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:16 UTC 2024 call : rmdir /mnt/part3 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:16 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Wed Nov  6 09:38:16 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 10%
Wed Nov  6 09:38:16 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 20%
Wed Nov  6 09:38:16 UTC 2024 func : _calculateStartAndEndSectors(245872640,250069646,4197007)
Wed Nov  6 09:38:16 UTC 2024 func : _alignSectorsDownTo1MiB(alignedRemainingSectorsPerPart,918691)
Wed Nov  6 09:38:16 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation fat32 245872640s 246921215s (/root/scripts/partitionHelper.sh:70)
Wed Nov  6 09:38:17 UTC 2024 call : mkfs -t fat /dev/sda5 (/root/scripts/partitionHelper.sh:76)
mkfs.fat 4.1 (2017-01-24)
Wed Nov  6 09:38:17 UTC 2024 func : getAhciPort(ahciPort, /dev/sda)
Wed Nov  6 09:38:17 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 5)
Wed Nov  6 09:38:17 UTC 2024 func : getEspPartition(espDev, espPart)
Wed Nov  6 09:38:17 UTC 2024 log  : ESP: /dev/sda 1
Wed Nov  6 09:38:17 UTC 2024 call : mkdir -p /mnt/part4 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:17 UTC 2024 call : mount /dev/sda1 /mnt/part4 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:17 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 5" into /mnt/part4/uninstall.cfg
Wed Nov  6 09:38:17 UTC 2024 call : umount /mnt/part4 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:17 UTC 2024 call : rmdir /mnt/part4 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:17 UTC 2024 call : dosfslabel /dev/sda5 SYSTEM (/root/scripts/partitionHelper.sh:80)
Wed Nov  6 09:38:17 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation1 fat32 246921216s 248016895s (/root/scripts/partitionHelper.sh:84)
Wed Nov  6 09:38:17 UTC 2024 call : mkfs -t fat /dev/sda6 (/root/scripts/partitionHelper.sh:87)
Wed Nov  6 09:38:17 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 6)
Wed Nov  6 09:38:17 UTC 2024 call : mkdir -p /mnt/part5 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:17 UTC 2024 call : mount /dev/sda1 /mnt/part5 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:17 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 6" into /mnt/part5/uninstall.cfg
Wed Nov  6 09:38:17 UTC 2024 call : umount /mnt/part5 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:17 UTC 2024 call : rmdir /mnt/part5 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:17 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation2 fat32 248016896s 248958975s (/root/scripts/partitionHelper.sh:84)
Wed Nov  6 09:38:17 UTC 2024 call : mkfs -t fat /dev/sda7 (/root/scripts/partitionHelper.sh:87)
Wed Nov  6 09:38:17 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 7)
Wed Nov  6 09:38:17 UTC 2024 call : mkdir -p /mnt/part6 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:17 UTC 2024 call : mount /dev/sda1 /mnt/part6 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:17 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 7" into /mnt/part6/uninstall.cfg
Wed Nov  6 09:38:18 UTC 2024 call : umount /mnt/part6 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:18 UTC 2024 call : rmdir /mnt/part6 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:18 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation3 fat32 248958976s 250069646s (/root/scripts/partitionHelper.sh:84)
Wed Nov  6 09:38:18 UTC 2024 call : mkfs -t fat /dev/sda8 (/root/scripts/partitionHelper.sh:87)
Wed Nov  6 09:38:18 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 8)
Wed Nov  6 09:38:18 UTC 2024 func : getEspPartition(espDev, espPart)
Wed Nov  6 09:38:18 UTC 2024 log  : ESP: /dev/sda 1
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part7 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:18 UTC 2024 call : mount /dev/sda1 /mnt/part7 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:18 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 8" into /mnt/part7/uninstall.cfg
Wed Nov  6 09:38:18 UTC 2024 call : umount /mnt/part7 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:18 UTC 2024 call : rmdir /mnt/part7 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:18 UTC 2024 call : dosfslabel /dev/sda6 RPSHD (/root/scripts/partitionHelper.sh:99)
Wed Nov  6 09:38:18 UTC 2024 call : dosfslabel /dev/sda7 RPSHDS (/root/scripts/partitionHelper.sh:101)
Wed Nov  6 09:38:18 UTC 2024 call : dosfslabel /dev/sda8 USER (/root/scripts/partitionHelper.sh:103)
Wed Nov  6 09:38:18 UTC 2024 info : partition for B&R Hypervisor and ARemb created on disk ATA SFCA128GH2AD4TO-
Wed Nov  6 09:38:18 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 35%
Wed Nov  6 09:38:18 UTC 2024 func : installInitialARemb(/dev/sda, , 5)
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part8 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:18 UTC 2024 call : mount /dev/sda5 /mnt/part8 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:18 UTC 2024 call : cp -f -r /root/BaseAR/* /mnt/part8 (/root/scripts/installInitialARemb.sh:32)
Wed Nov  6 09:38:18 UTC 2024 call : touch /mnt/part8/log.txt (/root/scripts/installInitialARemb.sh:33)
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part9 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:18 UTC 2024 call : mount /dev/sda6 /mnt/part9 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part10 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:18 UTC 2024 call : mount /dev/sda7 /mnt/part10 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part9/RPSHD/SYSROM (/root/scripts/installInitialARemb.sh:59)
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part10/RPSHDS/SYSROM (/root/scripts/installInitialARemb.sh:60)
Wed Nov  6 09:38:18 UTC 2024 call : mv -f /mnt/part8/*.br /mnt/part9/RPSHD/SYSROM (/root/scripts/installInitialARemb.sh:61)
Wed Nov  6 09:38:18 UTC 2024 call : cp -f /mnt/part9/RPSHD/SYSROM/*.br /mnt/part10/RPSHDS/SYSROM (/root/scripts/installInitialARemb.sh:62)
Wed Nov  6 09:38:18 UTC 2024 func : _installTransferModule(/mnt/part9)
Wed Nov  6 09:38:18 UTC 2024 func : getTransferModuleName(transferModuleName)
Wed Nov  6 09:38:18 UTC 2024 func : _getPipConfig(pipConfig)
Wed Nov  6 09:38:18 UTC 2024 call : mkdir -p /mnt/part9/TRANSFER (/root/scripts/installInitialARemb.sh:94)
Wed Nov  6 09:38:18 UTC 2024 call : cp -f /Setup/PIP/artransfer.br /mnt/part9/TRANSFER/artransfer.br (/root/scripts/installInitialARemb.sh:95)
Wed Nov  6 09:38:19 UTC 2024 info : artransfer.br copied
Wed Nov  6 09:38:19 UTC 2024 call : umount /mnt/part10 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:19 UTC 2024 call : rmdir /mnt/part10 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:19 UTC 2024 call : umount /mnt/part9 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:19 UTC 2024 call : rmdir /mnt/part9 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:19 UTC 2024 call : umount /mnt/part8 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:20 UTC 2024 call : rmdir /mnt/part8 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:20 UTC 2024 info : ARemb installed
Wed Nov  6 09:38:20 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 50%
Wed Nov  6 09:38:20 UTC 2024 func : installHypervisorFiles(/dev/sda, , 5)
Wed Nov  6 09:38:20 UTC 2024 call : mkdir -p /mnt/part11 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:20 UTC 2024 call : mount /dev/sda5 /mnt/part11 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:20 UTC 2024 call : mkdir -p /mnt/part11/SYSTEM/RTH (/root/scripts/hypervisorHelper.sh:30)
Wed Nov  6 09:38:20 UTC 2024 call : cp -f /root/BaseAR/System/RTH/rthx86 /mnt/part11/SYSTEM/RTH/ (/root/scripts/hypervisorHelper.sh:33)
Wed Nov  6 09:38:20 UTC 2024 call : cp -f /root/BaseAR/System/RTH/license.txt /mnt/part11/SYSTEM/RTH/ (/root/scripts/hypervisorHelper.sh:33)
Wed Nov  6 09:38:20 UTC 2024 call : touch /mnt/part11/log.txt (/root/scripts/hypervisorHelper.sh:35)
Wed Nov  6 09:38:20 UTC 2024 call : umount /mnt/part11 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:20 UTC 2024 call : rmdir /mnt/part11 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:20 UTC 2024 info : B&R hypervisor installed
Wed Nov  6 09:38:20 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 60%
Wed Nov  6 09:38:20 UTC 2024 func : installUefiGrub2(gposName, bootline, /EFI/grub/efiPartMarker_ndr7W3NhJy, /dev/sda, 1)
Wed Nov  6 09:38:20 UTC 2024 call : mkdir -p /boot/efi (/root/scripts/uefiInstallGrub2.sh:20)
Wed Nov  6 09:38:20 UTC 2024 call : mount /dev/sda1 /boot/efi (/root/scripts/uefiInstallGrub2.sh:21)
Wed Nov  6 09:38:20 UTC 2024 log  : used kernel: 5.12.4-x86
Wed Nov  6 09:38:20 UTC 2024 log  : needed kernel: 5.12.4-x86
Wed Nov  6 09:38:20 UTC 2024 call : ln -s /lib/modules/5.12.4-x86 /lib/modules/5.12.4-x86 (/root/scripts/uefiInstallGrub2.sh:29)
Wed Nov  6 09:38:20 UTC 2024 call : grub-install --target=x86_64-efi --efi-directory=/boot/efi --directory=/usr/lib/grub/x86_64-efi --locale-directory=/usr/share/locale --boot-directory=/boot/efi/EFI --bootloader-id=BR\ Hypervisor (/root/scripts/uefiInstallGrub2.sh:32)
Installing for x86_64-efi platform.
Installation finished. No error reported.
Wed Nov  6 09:38:21 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Wed Nov  6 09:38:21 UTC 2024 func : getAhciPort(ahciPort, /dev/sda)
Wed Nov  6 09:38:21 UTC 2024 func : logWriteAddUninstallCmd(delDir 0 1 "/EFI/grub")
Wed Nov  6 09:38:21 UTC 2024 func : getEspPartition(espDev, espPart)
Wed Nov  6 09:38:21 UTC 2024 log  : ESP: /dev/sda 1
Wed Nov  6 09:38:21 UTC 2024 call : mkdir -p /mnt/part12 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:21 UTC 2024 call : mount /dev/sda1 /mnt/part12 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:21 UTC 2024 log  : adding entry for uninstallation "echo delDir 0 1 "/EFI/grub"" into /mnt/part12/uninstall.cfg
Wed Nov  6 09:38:21 UTC 2024 call : umount /mnt/part12 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:21 UTC 2024 call : rmdir /mnt/part12 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:21 UTC 2024 func : logWriteAddUninstallCmd(delDir 0 1 "/EFI/BR Hypervisor")
Wed Nov  6 09:38:21 UTC 2024 call : mkdir -p /mnt/part13 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:21 UTC 2024 call : mount /dev/sda1 /mnt/part13 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:21 UTC 2024 log  : adding entry for uninstallation "echo delDir 0 1 "/EFI/BR Hypervisor"" into /mnt/part13/uninstall.cfg
Wed Nov  6 09:38:21 UTC 2024 call : umount /mnt/part13 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:21 UTC 2024 call : rmdir /mnt/part13 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:21 UTC 2024 func : logWriteAddUninstallCmd(delEfiBootEntry "BR Hypervisor")
Wed Nov  6 09:38:21 UTC 2024 call : mkdir -p /mnt/part14 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:21 UTC 2024 call : mount /dev/sda1 /mnt/part14 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:21 UTC 2024 log  : adding entry for uninstallation "echo delEfiBootEntry "BR Hypervisor"" into /mnt/part14/uninstall.cfg
Wed Nov  6 09:38:21 UTC 2024 call : umount /mnt/part14 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:21 UTC 2024 call : rmdir /mnt/part14 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:21 UTC 2024 call : cp /boot/efi/EFI/BR\ Hypervisor/grubx64.efi /boot/efi/EFI/grub/efiPartMarker_ndr7W3NhJy (/root/scripts/uefiInstallGrub2.sh:45)
Wed Nov  6 09:38:21 UTC 2024 call : umount /boot/efi (/root/scripts/uefiInstallGrub2.sh:46)
Wed Nov  6 09:38:21 UTC 2024 call : rmdir /boot/efi (/root/scripts/uefiInstallGrub2.sh:47)
Wed Nov  6 09:38:21 UTC 2024 call : rmdir /boot (/root/scripts/uefiInstallGrub2.sh:48)
Wed Nov  6 09:38:21 UTC 2024 call : mkdir -p /mnt/part15 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:21 UTC 2024 call : mount /dev/sda1 /mnt/part15 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:21 UTC 2024 func : _createGrub2Cfg(gpos, /mnt/part15, /mnt/part15/EFI/grub/grub.cfg, /EFI/grub/efiPartMarker_ndr7W3NhJy)
Wed Nov  6 09:38:21 UTC 2024 func : copyWindowsEfiDir(/mnt/part15)
Wed Nov  6 09:38:21 UTC 2024 call : cp -r /mnt/part15/EFI/* /mnt/part15/EFI.saved (/root/scripts/uefiEsp.sh:89)
cp: can't create directory '/mnt/part15/EFI.saved/BR Hypervisor': No such file or directory
cp: can't create directory '/mnt/part15/EFI.saved/Boot': No such file or directory
cp: can't create directory '/mnt/part15/EFI.saved/Microsoft': No such file or directory
cp: can't create directory '/mnt/part15/EFI.saved/grub': No such file or directory
Wed Nov  6 09:38:21 UTC 2024 log  : adding grub2 entry for rth with windows
Wed Nov  6 09:38:21 UTC 2024 log  : adding grub2 entry for ARemb
Wed Nov  6 09:38:21 UTC 2024 log  : adding grub2 defaults
Wed Nov  6 09:38:21 UTC 2024 log  : /mnt/part15/EFI/grub/grub.cfg:
Wed Nov  6 09:38:21 UTC 2024 log  :     search -f /EFI/grub/efiPartMarker_ndr7W3NhJy -s efiPart
Wed Nov  6 09:38:21 UTC 2024 log  :     regexp --set=1:diskHint "(hd[0-9]{1,2},)" "${efiPart}"
Wed Nov  6 09:38:21 UTC 2024 log  :     menuentry "Windows" {
Wed Nov  6 09:38:21 UTC 2024 log  :         root=$efiPart
Wed Nov  6 09:38:21 UTC 2024 log  :         chainloader /EFI/Microsoft/Boot/bootmgfw.efi
Wed Nov  6 09:38:21 UTC 2024 log  :         boot
Wed Nov  6 09:38:21 UTC 2024 log  :     }
Wed Nov  6 09:38:21 UTC 2024 log  :     menuentry "BR Hypervisor" {
Wed Nov  6 09:38:21 UTC 2024 log  :         insmod all_video
Wed Nov  6 09:38:21 UTC 2024 log  :         search -f   /SYSTEM/RTH/rthx86 -s -h $diskHint
Wed Nov  6 09:38:21 UTC 2024 log  :         multiboot2  /SYSTEM/RTH/rthx86 loglevel=8 tracefile=log.txt
Thank you very Much :slight_smile:
And the second Part.
Wed Nov  6 09:38:21 UTC 2024 log  :         module2     /SYSTEM/RTH/license.txt
Wed Nov  6 09:38:21 UTC 2024 log  :         module2     /SYSTEM/RTH/ARemb.txt
Wed Nov  6 09:38:21 UTC 2024 log  :         module2     /arimg          arimg
Wed Nov  6 09:38:21 UTC 2024 log  :         module2     /EFI/Microsoft/Boot/bootmgfw.efi /EFI/grub/efiPartMarker_ndr7W3NhJy
Wed Nov  6 09:38:21 UTC 2024 log  :     set timeout=1
Wed Nov  6 09:38:21 UTC 2024 log  :     set default="BR Hypervisor"
Wed Nov  6 09:38:21 UTC 2024 call : umount /mnt/part15 (/root/scripts/uefiInstallGrub2.sh:62)
Wed Nov  6 09:38:21 UTC 2024 info : Grub2 installed
Wed Nov  6 09:38:21 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 80%
Wed Nov  6 09:38:21 UTC 2024 func : installUefiHypervisorCfg(/dev/sda, /dev/sda, , 5, efiPartMarker_ndr7W3NhJy, Windows, )
Wed Nov  6 09:38:21 UTC 2024 call : mkdir -p /mnt/part16 (/root/scripts/helper.sh:144)
Wed Nov  6 09:38:21 UTC 2024 call : mount /dev/sda5 /mnt/part16 (/root/scripts/helper.sh:145)
Wed Nov  6 09:38:21 UTC 2024 func : createRthCfgHeader(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 log  : creating RTH config file header: createRthCfgHeader(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 func : getPciDriveParameters(pciBus, pciDevice, pciFunction)
Wed Nov  6 09:38:21 UTC 2024 log  : drive parameters: (00:17:0)
Wed Nov  6 09:38:21 UTC 2024 func : addRthCfgDriveEntry(/dev/sda, /dev/sda, 4, /mnt/part16/SYSTEM/RTH/ARemb.txt, 00, 17, 0)
Wed Nov  6 09:38:21 UTC 2024 func : _writeRthCfgDrivePartitionEntry(0, 4, /mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 func : _writeRthCfgDriveEntry(00, 17, 0, 0, 0, /mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 func : _writeRthCfgDriveEntry(00, 17, 0, 1, 1, /mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 func : _writeRthCfgDriveEntry(00, 17, 0, 2, 2, /mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 func : addRthCfgIoRanges(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 log  : adding entries for IO ranges: addRthCfgIoRanges(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:21 UTC 2024 func : addRthCfgIoRangeMtcx(/mnt/part16/SYSTEM/RTH/ARemb.txt, 0)
Wed Nov  6 09:38:22 UTC 2024 log  : adding IO range entry for MTCX
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgIoRangeNmi(/mnt/part16/SYSTEM/RTH/ARemb.txt, 1)
Wed Nov  6 09:38:22 UTC 2024 log  : adding IO range entry for NMI
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgIoRangePostCodes(/mnt/part16/SYSTEM/RTH/ARemb.txt, 2)
Wed Nov  6 09:38:22 UTC 2024 log  : adding IO range entry for POST codes
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgIoRangePiix(/mnt/part16/SYSTEM/RTH/ARemb.txt, 3)
Wed Nov  6 09:38:22 UTC 2024 log  : adding IO range entry for PIIX driver
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgIRQ(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 log  : adding entry for IRQ: addRthCfgIRQ(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 log  : adding RTH cfg GPOS image entry and bootline
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgOsEntries(Windows, /mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 log  : adding OS entries: addRthCfgOsEntries(Windows, /mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 func : _addRthCfgPciDefaults(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgShmEntries(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgSystemEntries(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 func : addRthCfgTimeSyncEntries(/mnt/part16/SYSTEM/RTH/ARemb.txt)
Wed Nov  6 09:38:22 UTC 2024 log  : /mnt/part16/SYSTEM/RTH/ARemb.txt:
Wed Nov  6 09:38:22 UTC 2024 log  :     # RTH CONFIG
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/0/PARTITION/4]
Wed Nov  6 09:38:22 UTC 2024 log  :         "OS"                     = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/0/PARTITION/5]
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/0/PARTITION/6]
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/0/PARTITION/7]
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "bus"                    = uint32: 0x00
Wed Nov  6 09:38:22 UTC 2024 log  :         "default"                = uint32: 0
Wed Nov  6 09:38:22 UTC 2024 log  :         "device"                 = uint32: 0x17
Wed Nov  6 09:38:22 UTC 2024 log  :         "function"               = uint32: 0x0
Wed Nov  6 09:38:22 UTC 2024 log  :         "port"                   = uint32: 0x0
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/1]
Wed Nov  6 09:38:22 UTC 2024 log  :         "port"                   = uint32: 0x1
Wed Nov  6 09:38:22 UTC 2024 log  :     [/DRIVE/2]
Wed Nov  6 09:38:22 UTC 2024 log  :         "port"                   = uint32: 0x2
Wed Nov  6 09:38:22 UTC 2024 log  :     # IO range for MTCX
Wed Nov  6 09:38:22 UTC 2024 log  :     [/IO_RANGE/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "base_port"              = uint32: 0x4000
Wed Nov  6 09:38:22 UTC 2024 log  :         "length"                 = uint32: 0x0200
Wed Nov  6 09:38:22 UTC 2024 log  :         "shared"                 = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :     # IO range for NMI
Wed Nov  6 09:38:22 UTC 2024 log  :     [/IO_RANGE/1]
Wed Nov  6 09:38:22 UTC 2024 log  :         "base_port"              = uint32: 0x61
Wed Nov  6 09:38:22 UTC 2024 log  :         "length"                 = uint32: 0x0001
Wed Nov  6 09:38:22 UTC 2024 log  :     # share IO range for POST codes
Wed Nov  6 09:38:22 UTC 2024 log  :     [/IO_RANGE/2]
Wed Nov  6 09:38:22 UTC 2024 log  :         "base_port"              = uint32: 0x80
Wed Nov  6 09:38:22 UTC 2024 log  :     # IO range for I82371AB_DELAY() in vxbPiixStorage driver
Wed Nov  6 09:38:22 UTC 2024 log  :     [/IO_RANGE/3]
Wed Nov  6 09:38:22 UTC 2024 log  :         "base_port"              = uint32: 0x84
Wed Nov  6 09:38:22 UTC 2024 log  :     [/IRQ]
Wed Nov  6 09:38:22 UTC 2024 log  :         "USB_SMI_disable"        = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :         "default"                = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :     [/OS/0/RUNTIME/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "image_0"                = "efiPartMarker_ndr7W3NhJy"
Wed Nov  6 09:38:22 UTC 2024 log  :     [/OS/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "boot_priority"          = uint32: 0
Wed Nov  6 09:38:22 UTC 2024 log  :         "name"                   = "Windows"
Wed Nov  6 09:38:22 UTC 2024 log  :         "trace_partition_number" = uint32: 0
Wed Nov  6 09:38:22 UTC 2024 log  :         "virtualized"            = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :     [/OS/1/RUNTIME/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "bootline"               = "vnet(0,0) e=192.168.2.2"
Wed Nov  6 09:38:22 UTC 2024 log  :         "image_0"                = "arimg"
Wed Nov  6 09:38:22 UTC 2024 log  :         "max_image_size_0"       = uint32: 0x2000000
Wed Nov  6 09:38:22 UTC 2024 log  :     [/OS/1]
Wed Nov  6 09:38:22 UTC 2024 log  :         "SMT"                    = uint32: 0
Wed Nov  6 09:38:22 UTC 2024 log  :         "boot_priority"          = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :         "cores"                  = bytelist: 1
Wed Nov  6 09:38:22 UTC 2024 log  :         "memory_size"            = uint64: 536870912
Wed Nov  6 09:38:22 UTC 2024 log  :         "name"                   = "ARemb"
Wed Nov  6 09:38:22 UTC 2024 log  :         "restricted_IO"          = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :         "virtual_MMU"            = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :     [/PCI/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "vendor_ID"              = uint32: 0x1677
Wed Nov  6 09:38:22 UTC 2024 log  :     [/PCI]
Wed Nov  6 09:38:22 UTC 2024 log  :     [/SHM/0]
Wed Nov  6 09:38:22 UTC 2024 log  :         "name"                   = "trace"
Wed Nov  6 09:38:22 UTC 2024 log  :         "size"                   = uint64: 0x4000
Wed Nov  6 09:38:22 UTC 2024 log  :     [/SYSTEM]
Wed Nov  6 09:38:22 UTC 2024 log  :         "IOMMU"                  = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :     [/TIME_SYNC]
Wed Nov  6 09:38:22 UTC 2024 log  :         "auto_start"             = uint32: 1
Wed Nov  6 09:38:22 UTC 2024 log  :         "master"                 = uint32: 0
Wed Nov  6 09:38:22 UTC 2024 log  :         "sync_interval"          = uint32: 1000
Wed Nov  6 09:38:22 UTC 2024 call : umount /mnt/part16 (/root/scripts/helper.sh:170)
Wed Nov  6 09:38:22 UTC 2024 call : rmdir /mnt/part16 (/root/scripts/helper.sh:171)
Wed Nov  6 09:38:22 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 90%
Wed Nov  6 09:38:22 UTC 2024 info : B&R Hypervisor installation finished.
Wed Nov  6 13:43:04 UTC 2024 info : B&R Hypervisor install / uninstall script started.
Wed Nov  6 13:43:04 UTC 2024 info : AR version: M4.93
Wed Nov  6 13:43:04 UTC 2024 info : SILENT_INSTALL=0
Wed Nov  6 13:43:04 UTC 2024 info : MIN_FREE_SPACE_IN_MB=0
Wed Nov  6 13:43:04 UTC 2024 info : DISK_NUMBER=
Wed Nov  6 13:43:04 UTC 2024 info : system info:
Wed Nov  6 13:43:04 UTC 2024 info : OEM string 1: 5APC3100.KBU1-C00
Wed Nov  6 13:43:04 UTC 2024 info : OEM string 2: 5ACCLI02.SD40-000
Wed Nov  6 13:43:04 UTC 2024 info : OEM string 3:
Wed Nov  6 13:43:04 UTC 2024 info : OEM string 4:
Wed Nov  6 13:43:04 UTC 2024 info : OEM string 5:
Wed Nov  6 13:43:04 UTC 2024 info : BIOS: a1.45 05/17/2024 Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 13:43:04 UTC 2024 info : system: APC3100 a1.45 / V4.27 F0BD0169495 03000200-0400-0500-0006-0f0bd0169495 Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 13:43:04 UTC 2024 info : baseboard: APC3100 5APC3100.KBU1-C00 F0BD0169495 APC3100 Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 13:43:04 UTC 2024 info : chassis: 5APC3100.KBU1-C00 F0BD0169495 Desktop Chassis Asset Tag Bernecker + Rainer  Industrie-Elektronik
Wed Nov  6 13:43:04 UTC 2024 info : processor: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz Core i3 2400 MHz Intel(R) Corporation
Wed Nov  6 13:43:04 UTC 2024 log  : ethernet:
Wed Nov  6 13:43:04 UTC 2024 log  :     enp0s31f6 Link encap:Ethernet  HWaddr 00:60:65:5E:01:66
Wed Nov  6 13:43:04 UTC 2024 log  :               UP BROADCAST MULTICAST  MTU:1500  Metric:1
Wed Nov  6 13:43:04 UTC 2024 log  :               RX packets:0 errors:0 dropped:0 overruns:0 frame:0
Wed Nov  6 13:43:04 UTC 2024 log  :               TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
Wed Nov  6 13:43:04 UTC 2024 log  :               collisions:0 txqueuelen:1000
Wed Nov  6 13:43:04 UTC 2024 log  :               RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
Wed Nov  6 13:43:04 UTC 2024 log  :               Interrupt:16 Memory:b1100000-b1120000
Wed Nov  6 13:43:04 UTC 2024 log  :     enp1s0    Link encap:Ethernet  HWaddr 00:60:65:5E:01:67
Wed Nov  6 13:43:04 UTC 2024 log  :               Memory:b1000000-b107ffff
Wed Nov  6 13:43:04 UTC 2024 log  :     lo        Link encap:Local Loopback
Wed Nov  6 13:43:04 UTC 2024 log  :               inet addr:127.0.0.1  Mask:255.0.0.0
Wed Nov  6 13:43:04 UTC 2024 log  :               UP LOOPBACK RUNNING  MTU:65536  Metric:1
Wed Nov  6 13:43:04 UTC 2024 log  : drives:
Wed Nov  6 13:43:05 UTC 2024 log  :     Model: ATA SFCA128GH2AD4TO- (scsi)
Wed Nov  6 13:43:05 UTC 2024 log  :     Disk /dev/sda: 128GB
Wed Nov  6 13:43:05 UTC 2024 log  :     Sector size (logical/physical): 512B/512B
Wed Nov  6 13:43:05 UTC 2024 log  :     Partition Table: gpt
Wed Nov  6 13:43:05 UTC 2024 log  :     Disk Flags:
Wed Nov  6 13:43:05 UTC 2024 log  :     Number  Start   End     Size    File system  Name                          Flags
Wed Nov  6 13:43:05 UTC 2024 log  :      1      1049kB  274MB   273MB   fat32        EFI system partition          boot, esp
Wed Nov  6 13:43:05 UTC 2024 log  :      2      274MB   290MB   16.8MB               Microsoft reserved partition  msftres
Wed Nov  6 13:43:05 UTC 2024 log  :      3      290MB   75.6GB  75.3GB  ntfs         Basic data partition          msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      4      75.6GB  126GB   50.3GB  ntfs         Basic data partition          msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      5      126GB   126GB   537MB   fat32        ARembInstallation             msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      6      126GB   127GB   561MB   fat32        ARembInstallation1            msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      7      127GB   127GB   482MB   fat16        ARembInstallation2            msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      8      127GB   128GB   569MB   fat32        ARembInstallation3            msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :     Model: Samsung Portable SSD T5 (scsi)
Wed Nov  6 13:43:05 UTC 2024 log  :     Disk /dev/sdb: 1000GB
Wed Nov  6 13:43:05 UTC 2024 log  :     Partition Table: msdos
Wed Nov  6 13:43:05 UTC 2024 log  :     Number  Start   End     Size    Type     File system  Flags
Wed Nov  6 13:43:05 UTC 2024 log  :      1      1049kB  1000GB  1000GB  primary
Wed Nov  6 13:43:05 UTC 2024 log  :     Model: SanDisk Cruzer Blade (scsi)
Wed Nov  6 13:43:05 UTC 2024 log  :     Disk /dev/sdc: 16.0GB
Wed Nov  6 13:43:05 UTC 2024 log  :      1      64.5kB  16.0GB  16.0GB  primary  fat32        boot
Wed Nov  6 13:43:05 UTC 2024 func : getMinPartitionSizes()
Wed Nov  6 13:43:05 UTC 2024 func : _getPipConfig(pipConfig)
Wed Nov  6 13:43:05 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,67108864)
Wed Nov  6 13:43:05 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,90292124)
Wed Nov  6 13:43:05 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,11592668)
Wed Nov  6 13:43:05 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,10485760)
Wed Nov  6 13:43:05 UTC 2024 log  : 255MB minimum AR disk size
Wed Nov  6 13:43:05 UTC 2024 log  : 173MB needed project space
Wed Nov  6 13:43:05 UTC 2024 log  : 255MB minimum CFast size
Wed Nov  6 13:43:05 UTC 2024 log  : UEFI GPOS detected
Wed Nov  6 13:43:05 UTC 2024 log  : information of device /dev/sda updated:
Wed Nov  6 13:43:05 UTC 2024 log  :     Disk /dev/sda: 250069680s
Wed Nov  6 13:43:05 UTC 2024 log  :             34s         2047s       2014s       Free Space
Wed Nov  6 13:43:05 UTC 2024 log  :      1      2048s       534527s     532480s     fat32        EFI system partition          boot, esp
Wed Nov  6 13:43:05 UTC 2024 log  :      2      534528s     567295s     32768s                   Microsoft reserved partition  msftres
Wed Nov  6 13:43:05 UTC 2024 log  :      3      567296s     147668991s  147101696s  ntfs         Basic data partition          msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      4      147668992s  245872639s  98203648s   ntfs         Basic data partition          msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      5      245872640s  246921215s  1048576s    fat32        ARembInstallation             msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      6      246921216s  248016895s  1095680s    fat32        ARembInstallation1            msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      7      248016896s  248958975s  942080s     fat16        ARembInstallation2            msftdata
Wed Nov  6 13:43:05 UTC 2024 log  :      8      248958976s  250069646s  1110671s    fat32        ARembInstallation3            msftdata
Wed Nov  6 13:43:05 UTC 2024 log  : information of device /dev/sdb updated:
Wed Nov  6 13:43:06 UTC 2024 log  :     Model: Samsung Portable SSD T5 (scsi)
Wed Nov  6 13:43:06 UTC 2024 log  :     Disk /dev/sdb: 1953525168s
Wed Nov  6 13:43:06 UTC 2024 log  :     Sector size (logical/physical): 512B/512B
Wed Nov  6 13:43:06 UTC 2024 log  :     Partition Table: msdos
Wed Nov  6 13:43:06 UTC 2024 log  :     Disk Flags:
Wed Nov  6 13:43:06 UTC 2024 log  :     Number  Start        End          Size         Type     File system  Flags
Wed Nov  6 13:43:06 UTC 2024 log  :             2s           2047s        2046s                 Free Space
Wed Nov  6 13:43:06 UTC 2024 log  :      1      2048s        1953522112s  1953520065s  primary
Wed Nov  6 13:43:06 UTC 2024 log  :             1953522113s  1953525167s  3055s                 Free Space
Wed Nov  6 13:43:06 UTC 2024 log  : information of device /dev/sdc updated:
Wed Nov  6 13:43:06 UTC 2024 log  :     Model: SanDisk Cruzer Blade (scsi)
Wed Nov  6 13:43:06 UTC 2024 log  :     Disk /dev/sdc: 31260672s
Wed Nov  6 13:43:06 UTC 2024 log  :             63s        125s       63s                 Free Space
Wed Nov  6 13:43:06 UTC 2024 log  :      1      126s       31246424s  31246299s  primary  fat32        boot
Wed Nov  6 13:43:06 UTC 2024 log  :             31246425s  31260671s  14247s              Free Space
Wed Nov  6 13:43:12 UTC 2024 call : mkdir -p /mnt/part1 (/root/scripts/helper.sh:144)
Wed Nov  6 13:43:12 UTC 2024 call : mount /dev/sdb1 /mnt/part1 (/root/scripts/helper.sh:145)
Wed Nov  6 13:43:12 UTC 2024 call : ntfsfix /dev/sdb1 (/root/scripts/helper.sh:156)
FAILED
FAILED
Unrecoverable error
Wed Nov  6 13:43:12 UTC 2024 call : mount -t ntfs-3g /dev/sdb1 /mnt/part1 (/root/scripts/helper.sh:157)
Failed to mount '/dev/sdb1': Invalid argument
The device '/dev/sdb1' doesn't seem to have a valid NTFS.
Wed Nov  6 13:43:12 UTC 2024 log  : device and partition information:
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda1, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     fat32, primary, 273, 0, 1.05MB, 274MB, EFI, boot, esp,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda2, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     unknown, , 16.8, 0, 274MB, 290MB, Microsoft, msftres,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda3, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     ntfs, , 75316, 0, 290MB, 75607MB, Basic, msftdata,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda4, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     ntfs, , 50280, 0, 75607MB, 125887MB, Basic, msftdata,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda5, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     fat32, , 537, 0, 125887MB, 126424MB, ARembInstallation, msftdata,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda6, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     fat32, , 561, 0, 126424MB, 126985MB, ARembInstallation1, msftdata,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda7, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     fat16, , 482, 0, 126985MB, 127467MB, ARembInstallation2, msftdata,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sda8, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Wed Nov  6 13:43:12 UTC 2024 log  :     fat32, , 569, 0, 127467MB, 128036MB, ARembInstallation3, msftdata,
Wed Nov  6 13:43:12 UTC 2024 log  : /dev/sdb1, 1: 1000GB, 512, 512, msdos, Samsung Portable SSD T5, , -, Windows
Wed Nov  6 13:43:12 UTC 2024 log  :     , , 1000202, 0, 1.05MB, 1000203MB, untitled, ,
Wed Nov  6 13:43:12 UTC 2024 func : _createUefiARembInstallationCandidates()
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,5,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,6,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,7,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,8,free)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,5,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,6,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,7,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,8,ARinst)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,5,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,6,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,7,all)
Wed Nov  6 13:43:12 UTC 2024 func : _getUefiPartitionString(candPartString,activated,8,all)
Wed Nov  6 13:43:12 UTC 2024 func : getEspPartition(espDev, espPart)
Wed Nov  6 13:43:12 UTC 2024 func : hasUninstallCfgFile(newUefiUninstallation)
Wed Nov  6 13:43:12 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Wed Nov  6 13:43:12 UTC 2024 call : mkdir -p /mnt/part2 (/root/scripts/helper.sh:144)
Wed Nov  6 13:43:12 UTC 2024 call : mount /dev/sda1 /mnt/part2 (/root/scripts/helper.sh:145)
Wed Nov  6 13:43:12 UTC 2024 call : umount /mnt/part2 (/root/scripts/helper.sh:170)
Wed Nov  6 13:43:12 UTC 2024 call : rmdir /mnt/part2 (/root/scripts/helper.sh:171)
Wed Nov  6 13:43:14 UTC 2024 log  : \nB&R Hypervisor is going to be uninstalled. 0%
Wed Nov  6 13:43:15 UTC 2024 info : B&R Hypervisor uninstallation started.
Wed Nov  6 13:43:15 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Wed Nov  6 13:43:15 UTC 2024 log  : \nB&R Hypervisor is going to be uninstalled. 20%
Wed Nov  6 13:43:15 UTC 2024 call : mkdir -p /mnt/part3 (/root/scripts/helper.sh:144)
Wed Nov  6 13:43:15 UTC 2024 call : mount /dev/sda1 /mnt/part3 (/root/scripts/helper.sh:145)
Wed Nov  6 13:43:15 UTC 2024 call : dos2unix /mnt/part3/uninstall.cfg (/root/scripts/uefiUninstallationFileCfg.sh:22)
dos2unix: converting file /mnt/part3/uninstall.cfg to Unix format...
Wed Nov  6 13:43:15 UTC 2024 log  : /mnt/part3/uninstall.cfg:
Wed Nov  6 13:43:15 UTC 2024 log  :     delPart 0 5
Wed Nov  6 13:43:15 UTC 2024 log  :     delPart 0 6
Wed Nov  6 13:43:15 UTC 2024 log  :     delPart 0 7
Wed Nov  6 13:43:15 UTC 2024 log  :     delPart 0 8
Wed Nov  6 13:43:15 UTC 2024 log  :     delDir 0 1 "/EFI/grub"
Wed Nov  6 13:43:15 UTC 2024 log  :     delDir 0 1 "/EFI/BR Hypervisor"
Wed Nov  6 13:43:15 UTC 2024 log  :     delEfiBootEntry "BR Hypervisor"
Wed Nov  6 13:43:15 UTC 2024 log  : \nB&R Hypervisor is going to be uninstalled. 30%
Wed Nov  6 13:43:15 UTC 2024 func : delPart(0, 5)
Wed Nov  6 13:43:15 UTC 2024 func : getDeviceFromAhciPort(device, 0)
Wed Nov  6 13:43:15 UTC 2024 call : parted -s /dev/sda rm 5 (/root/scripts/uefiUninstallationCallFileCfg.sh:79)
Wed Nov  6 13:43:15 UTC 2024 func : delPart(0, 6)
Wed Nov  6 13:43:15 UTC 2024 call : parted -s /dev/sda rm 6 (/root/scripts/uefiUninstallationCallFileCfg.sh:79)
Wed Nov  6 13:43:15 UTC 2024 func : delPart(0, 7)
Wed Nov  6 13:43:15 UTC 2024 call : parted -s /dev/sda rm 7 (/root/scripts/uefiUninstallationCallFileCfg.sh:79)
Wed Nov  6 13:43:15 UTC 2024 func : delPart(0, 8)
Wed Nov  6 13:43:15 UTC 2024 call : parted -s /dev/sda rm 8 (/root/scripts/uefiUninstallationCallFileCfg.sh:79)
Wed Nov  6 13:43:16 UTC 2024 func : delDir(0, 1, /EFI/grub)
Wed Nov  6 13:43:16 UTC 2024 func : getDeviceFromAhciPort(device, 0)
Wed Nov  6 13:43:16 UTC 2024 call : mkdir -p /mnt/part100 (/root/scripts/helper.sh:144)
Wed Nov  6 13:43:16 UTC 2024 call : mount /dev/sda1 /mnt/part100 (/root/scripts/helper.sh:145)
Wed Nov  6 13:43:16 UTC 2024 call : rm -r /mnt/part100/EFI/grub (/root/scripts/uefiUninstallationCallFileCfg.sh:46)
Wed Nov  6 13:43:16 UTC 2024 call : umount /mnt/part100 (/root/scripts/helper.sh:170)
Wed Nov  6 13:43:16 UTC 2024 call : rmdir /mnt/part100 (/root/scripts/helper.sh:171)
Wed Nov  6 13:43:16 UTC 2024 func : delDir(0, 1, /EFI/BR Hypervisor)
Wed Nov  6 13:43:16 UTC 2024 call : mkdir -p /mnt/part101 (/root/scripts/helper.sh:144)
Wed Nov  6 13:43:16 UTC 2024 call : mount /dev/sda1 /mnt/part101 (/root/scripts/helper.sh:145)
Wed Nov  6 13:43:16 UTC 2024 call : rm -r /mnt/part101/EFI/BR\ Hypervisor (/root/scripts/uefiUninstallationCallFileCfg.sh:46)
Wed Nov  6 13:43:16 UTC 2024 call : umount /mnt/part101 (/root/scripts/helper.sh:170)
Wed Nov  6 13:43:16 UTC 2024 call : rmdir /mnt/part101 (/root/scripts/helper.sh:171)
Wed Nov  6 13:43:16 UTC 2024 func : delEfiBootEntry(BR Hypervisor)
Wed Nov  6 13:43:16 UTC 2024 call : efibootmgr -b 0005 -B (/root/scripts/uefiUninstallationCallFileCfg.sh:92)
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0006,0000,0004,0003,2001,2002,2003,0001,0002
Boot0000* UEFI OS
Boot0001* SanDisk
Boot0002* Samsung Portable SSD T5
Boot0003* SFCA128GH2AD4TO-I-LT-226-STD
Boot0004* Internal EFI Shell
Boot0006* Windows Boot Manager
Boot2001* EFI USB Device
Boot2002* EFI DVD/CDROM
Boot2003* EFI Network
Wed Nov  6 13:43:16 UTC 2024 log  : \nB&R Hypervisor is going to be uninstalled. 70%
Wed Nov  6 13:43:16 UTC 2024 call : rm -f /mnt/part3/uninstall.cfg (/root/scripts/uefiUninstallationFileCfg.sh:31)
Wed Nov  6 13:43:16 UTC 2024 log  : \nB&R Hypervisor is going to be uninstalled. 90%
Wed Nov  6 13:43:16 UTC 2024 call : umount /mnt/part3 (/root/scripts/helper.sh:170)
Wed Nov  6 13:43:16 UTC 2024 call : rmdir /mnt/part3 (/root/scripts/helper.sh:171)
Wed Nov  6 13:43:16 UTC 2024 log  : \nB&R Hypervisor is going to be uninstalled. 100%
Wed Nov  6 13:43:16 UTC 2024 info : B&R Hypervisor uninstallation finished.
Wed Nov  6 13:43:16 UTC 2024 log  : ok reboot dialog: B&R Hypervisor Uninstallation finished. - Uninstallation successfully completed.
HI, is there the disk, the USB stick and an additional external disk?
Yes, a portable SSD is connected via USB to the APC3100.
was USB SSD disk plugged into APC during hypervisor installation? if so, can you try installation without?
I disconnected the SSD and the error vanished from the install log but still no successful boot.
Fri Nov  8 09:26:40 UTC 2024 info : B&R Hypervisor install / uninstall script started.
Fri Nov  8 09:26:40 UTC 2024 info : AR version: M4.93
Fri Nov  8 09:26:40 UTC 2024 info : SILENT_INSTALL=0
Fri Nov  8 09:26:40 UTC 2024 info : MIN_FREE_SPACE_IN_MB=0
Fri Nov  8 09:26:40 UTC 2024 info : DISK_NUMBER=
Fri Nov  8 09:26:40 UTC 2024 info : system info:
Fri Nov  8 09:26:40 UTC 2024 info : OEM string 1: 5APC3100.KBU1-C00
Fri Nov  8 09:26:40 UTC 2024 info : OEM string 2: 5ACCLI02.SD40-000
Fri Nov  8 09:26:40 UTC 2024 info : OEM string 3:
Fri Nov  8 09:26:40 UTC 2024 info : OEM string 4:
Fri Nov  8 09:26:40 UTC 2024 info : OEM string 5:
Fri Nov  8 09:26:40 UTC 2024 info : BIOS: a1.45 05/17/2024 Bernecker + Rainer  Industrie-Elektronik
Fri Nov  8 09:26:40 UTC 2024 info : system: APC3100 a1.45 / V4.27 F0BD0169495 03000200-0400-0500-0006-0f0bd0169495 Bernecker + Rainer  Industrie-Elektronik
Fri Nov  8 09:26:40 UTC 2024 info : baseboard: APC3100 5APC3100.KBU1-C00 F0BD0169495 APC3100 Bernecker + Rainer  Industrie-Elektronik
Fri Nov  8 09:26:41 UTC 2024 info : chassis: 5APC3100.KBU1-C00 F0BD0169495 Desktop Chassis Asset Tag Bernecker + Rainer  Industrie-Elektronik
Fri Nov  8 09:26:41 UTC 2024 info : processor: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz Core i3 2400 MHz Intel(R) Corporation
Fri Nov  8 09:26:41 UTC 2024 log  : ethernet:
Fri Nov  8 09:26:41 UTC 2024 log  :     enp0s31f6 Link encap:Ethernet  HWaddr 00:60:65:5E:01:66
Fri Nov  8 09:26:41 UTC 2024 log  :               UP BROADCAST MULTICAST  MTU:1500  Metric:1
Fri Nov  8 09:26:41 UTC 2024 log  :               RX packets:0 errors:0 dropped:0 overruns:0 frame:0
Fri Nov  8 09:26:41 UTC 2024 log  :               TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
Fri Nov  8 09:26:41 UTC 2024 log  :               collisions:0 txqueuelen:1000
Fri Nov  8 09:26:41 UTC 2024 log  :               RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
Fri Nov  8 09:26:41 UTC 2024 log  :               Interrupt:16 Memory:b1100000-b1120000
Fri Nov  8 09:26:41 UTC 2024 log  :     enp1s0    Link encap:Ethernet  HWaddr 00:60:65:5E:01:67
Fri Nov  8 09:26:41 UTC 2024 log  :               Memory:b1000000-b107ffff
Fri Nov  8 09:26:41 UTC 2024 log  :     lo        Link encap:Local Loopback
Fri Nov  8 09:26:41 UTC 2024 log  :               inet addr:127.0.0.1  Mask:255.0.0.0
Fri Nov  8 09:26:41 UTC 2024 log  :               UP LOOPBACK RUNNING  MTU:65536  Metric:1
Fri Nov  8 09:26:41 UTC 2024 log  : drives:
Fri Nov  8 09:26:41 UTC 2024 log  :     Model: ATA SFCA128GH2AD4TO- (scsi)
Fri Nov  8 09:26:41 UTC 2024 log  :     Disk /dev/sda: 128GB
Fri Nov  8 09:26:41 UTC 2024 log  :     Sector size (logical/physical): 512B/512B
Fri Nov  8 09:26:41 UTC 2024 log  :     Partition Table: gpt
Fri Nov  8 09:26:41 UTC 2024 log  :     Disk Flags:
Fri Nov  8 09:26:41 UTC 2024 log  :     Number  Start   End     Size    File system  Name                          Flags
Fri Nov  8 09:26:41 UTC 2024 log  :      1      1049kB  274MB   273MB   fat32        EFI system partition          boot, esp
Fri Nov  8 09:26:41 UTC 2024 log  :      2      274MB   290MB   16.8MB               Microsoft reserved partition  msftres
Fri Nov  8 09:26:41 UTC 2024 log  :      3      290MB   75.6GB  75.3GB  ntfs         Basic data partition          msftdata
Fri Nov  8 09:26:41 UTC 2024 log  :      4      75.6GB  118GB   41.9GB  ntfs         Basic data partition          msftdata
Fri Nov  8 09:26:41 UTC 2024 log  :     Model: SanDisk Cruzer Blade (scsi)
Fri Nov  8 09:26:41 UTC 2024 log  :     Disk /dev/sdb: 16.0GB
Fri Nov  8 09:26:41 UTC 2024 log  :     Partition Table: msdos
Fri Nov  8 09:26:41 UTC 2024 log  :     Number  Start   End     Size    Type     File system  Flags
Fri Nov  8 09:26:41 UTC 2024 log  :      1      64.5kB  16.0GB  16.0GB  primary  fat32        boot
Fri Nov  8 09:26:41 UTC 2024 func : getMinPartitionSizes()
Fri Nov  8 09:26:41 UTC 2024 func : _getPipConfig(pipConfig)
Fri Nov  8 09:26:41 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,67108864)
Fri Nov  8 09:26:41 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,90292124)
Fri Nov  8 09:26:41 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,11592668)
Fri Nov  8 09:26:41 UTC 2024 func : _roundUpTo1MiB(roundedPartSize,10485760)
Fri Nov  8 09:26:41 UTC 2024 log  : 255MB minimum AR disk size
Fri Nov  8 09:26:41 UTC 2024 log  : 173MB needed project space
Fri Nov  8 09:26:41 UTC 2024 log  : 255MB minimum CFast size
Fri Nov  8 09:26:41 UTC 2024 log  : UEFI GPOS detected
Fri Nov  8 09:26:41 UTC 2024 log  : information of device /dev/sda updated:
Fri Nov  8 09:26:41 UTC 2024 log  :     Disk /dev/sda: 250069680s
Fri Nov  8 09:26:41 UTC 2024 log  :             34s         2047s       2014s       Free Space
Fri Nov  8 09:26:41 UTC 2024 log  :      1      2048s       534527s     532480s     fat32        EFI system partition          boot, esp
Fri Nov  8 09:26:41 UTC 2024 log  :      2      534528s     567295s     32768s                   Microsoft reserved partition  msftres
Fri Nov  8 09:26:41 UTC 2024 log  :      3      567296s     147668991s  147101696s  ntfs         Basic data partition          msftdata
Fri Nov  8 09:26:41 UTC 2024 log  :      4      147668992s  229586943s  81917952s   ntfs         Basic data partition          msftdata
Fri Nov  8 09:26:41 UTC 2024 log  :             229586944s  250069646s  20482703s   Free Space
Fri Nov  8 09:26:41 UTC 2024 log  : information of device /dev/sdb updated:
Fri Nov  8 09:26:41 UTC 2024 log  :     Disk /dev/sdb: 31260672s
Fri Nov  8 09:26:41 UTC 2024 log  :             63s        125s       63s                 Free Space
Fri Nov  8 09:26:41 UTC 2024 log  :      1      126s       31246424s  31246299s  primary  fat32        boot
Fri Nov  8 09:26:41 UTC 2024 log  :             31246425s  31260671s  14247s              Free Space
Fri Nov  8 09:26:43 UTC 2024 log  : device and partition information:
Fri Nov  8 09:26:43 UTC 2024 log  : /dev/sda1, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Fri Nov  8 09:26:43 UTC 2024 log  :     fat32, , 273, 0, 1.05MB, 274MB, EFI, boot, esp,
Fri Nov  8 09:26:43 UTC 2024 log  : /dev/sda2, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Fri Nov  8 09:26:43 UTC 2024 log  :     unknown, , 16.8, 0, 274MB, 290MB, Microsoft, msftres,
Fri Nov  8 09:26:43 UTC 2024 log  : /dev/sda3, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Fri Nov  8 09:26:43 UTC 2024 log  :     ntfs, , 75316, 0, 290MB, 75607MB, Basic, msftdata,
Fri Nov  8 09:26:43 UTC 2024 log  : /dev/sda4, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Fri Nov  8 09:26:43 UTC 2024 log  :     ntfs, , 41942, 0, 75607MB, 117549MB, Basic, msftdata,
Fri Nov  8 09:26:43 UTC 2024 log  : /dev/sda, 0: 128GB, 512, 512, gpt, ATA SFCA128GH2AD4TO-, , -, Linux
Fri Nov  8 09:26:43 UTC 2024 log  :     Free, , 10487, 0, 117549MB, 128036MB, unallocated, ,
Fri Nov  8 09:26:43 UTC 2024 func : _createUefiARembInstallationCandidates()
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,free)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,free)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,free)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,free)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,free)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,ARinst)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,ARinst)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,ARinst)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,ARinst)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,ARinst)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,0,all)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,1,all)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,2,all)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,3,all)
Fri Nov  8 09:26:43 UTC 2024 func : _getUefiPartitionString(candPartString,activated,4,all)
Fri Nov  8 09:26:43 UTC 2024 func : getEspPartition(espDev, espPart)
Fri Nov  8 09:26:43 UTC 2024 func : hasUninstallCfgFile(newUefiUninstallation)
Fri Nov  8 09:26:43 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Fri Nov  8 09:26:43 UTC 2024 call : mkdir -p /mnt/part1 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:43 UTC 2024 call : mount /dev/sda1 /mnt/part1 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:43 UTC 2024 call : umount /mnt/part1 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:43 UTC 2024 call : rmdir /mnt/part1 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:55 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 0%
Fri Nov  8 09:26:55 UTC 2024 info : B&R Hypervisor efiPartMarker_ACghbPiRj0 installation started.
Fri Nov  8 09:26:55 UTC 2024 func : logWriteInitUninstallFile()
Fri Nov  8 09:26:55 UTC 2024 func : getEspPartition(espDev, espPart)
Fri Nov  8 09:26:55 UTC 2024 log  : ESP: /dev/sda 1
Fri Nov  8 09:26:55 UTC 2024 call : mkdir -p /mnt/part2 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:55 UTC 2024 call : mount /dev/sda1 /mnt/part2 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:55 UTC 2024 log  : emptying uninstallation file /mnt/part2/uninstall.cfg
Fri Nov  8 09:26:55 UTC 2024 call : umount /mnt/part2 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:56 UTC 2024 call : rmdir /mnt/part2 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:56 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Fri Nov  8 09:26:56 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 10%
Fri Nov  8 09:26:56 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 20%
Fri Nov  8 09:26:56 UTC 2024 func : _calculateStartAndEndSectors(229586944,250069646,20482703)
Fri Nov  8 09:26:56 UTC 2024 func : _alignSectorsDownTo1MiB(alignedRemainingSectorsPerPart,4990115)
Fri Nov  8 09:26:56 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation fat32 229586944s 234706943s (/root/scripts/partitionHelper.sh:70)
Fri Nov  8 09:26:56 UTC 2024 call : mkfs -t fat /dev/sda5 (/root/scripts/partitionHelper.sh:76)
Fri Nov  8 09:26:56 UTC 2024 func : getAhciPort(ahciPort, /dev/sda)
Fri Nov  8 09:26:56 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 5)
Fri Nov  8 09:26:56 UTC 2024 func : getEspPartition(espDev, espPart)
Fri Nov  8 09:26:56 UTC 2024 log  : ESP: /dev/sda 1
Fri Nov  8 09:26:56 UTC 2024 call : mkdir -p /mnt/part3 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:56 UTC 2024 call : mount /dev/sda1 /mnt/part3 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:56 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 5" into /mnt/part3/uninstall.cfg
Fri Nov  8 09:26:56 UTC 2024 call : umount /mnt/part3 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:56 UTC 2024 call : rmdir /mnt/part3 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:56 UTC 2024 call : dosfslabel /dev/sda5 SYSTEM (/root/scripts/partitionHelper.sh:80)
Fri Nov  8 09:26:56 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation1 fat32 234706944s 239874047s (/root/scripts/partitionHelper.sh:84)
Fri Nov  8 09:26:56 UTC 2024 call : mkfs -t fat /dev/sda6 (/root/scripts/partitionHelper.sh:87)
Fri Nov  8 09:26:56 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 6)
Fri Nov  8 09:26:56 UTC 2024 call : mkdir -p /mnt/part4 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:56 UTC 2024 call : mount /dev/sda1 /mnt/part4 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:57 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 6" into /mnt/part4/uninstall.cfg
Fri Nov  8 09:26:57 UTC 2024 call : umount /mnt/part4 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:57 UTC 2024 call : rmdir /mnt/part4 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:57 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation2 fat32 239874048s 244887551s (/root/scripts/partitionHelper.sh:84)
Fri Nov  8 09:26:57 UTC 2024 call : mkfs -t fat /dev/sda7 (/root/scripts/partitionHelper.sh:87)
Fri Nov  8 09:26:57 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 7)
Fri Nov  8 09:26:57 UTC 2024 func : getEspPartition(espDev, espPart)
Fri Nov  8 09:26:57 UTC 2024 log  : ESP: /dev/sda 1
Fri Nov  8 09:26:57 UTC 2024 call : mkdir -p /mnt/part5 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:57 UTC 2024 call : mount /dev/sda1 /mnt/part5 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:57 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 7" into /mnt/part5/uninstall.cfg
Fri Nov  8 09:26:57 UTC 2024 call : umount /mnt/part5 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:57 UTC 2024 call : rmdir /mnt/part5 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:57 UTC 2024 call : parted -s /dev/sda mkpart ARembInstallation3 fat32 244887552s 250069646s (/root/scripts/partitionHelper.sh:84)
Fri Nov  8 09:26:57 UTC 2024 call : mkfs -t fat /dev/sda8 (/root/scripts/partitionHelper.sh:87)
Fri Nov  8 09:26:57 UTC 2024 func : logWriteAddUninstallCmd(delPart 0 8)
Fri Nov  8 09:26:57 UTC 2024 call : mkdir -p /mnt/part6 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:57 UTC 2024 call : mount /dev/sda1 /mnt/part6 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:57 UTC 2024 log  : adding entry for uninstallation "echo delPart 0 8" into /mnt/part6/uninstall.cfg
Fri Nov  8 09:26:57 UTC 2024 call : umount /mnt/part6 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:57 UTC 2024 call : rmdir /mnt/part6 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:57 UTC 2024 call : dosfslabel /dev/sda6 RPSHD (/root/scripts/partitionHelper.sh:99)
Fri Nov  8 09:26:57 UTC 2024 call : dosfslabel /dev/sda7 RPSHDS (/root/scripts/partitionHelper.sh:101)
Fri Nov  8 09:26:57 UTC 2024 call : dosfslabel /dev/sda8 USER (/root/scripts/partitionHelper.sh:103)
Fri Nov  8 09:26:57 UTC 2024 info : partition for B&R Hypervisor and ARemb created on disk ATA SFCA128GH2AD4TO-
Fri Nov  8 09:26:57 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 35%
Fri Nov  8 09:26:57 UTC 2024 func : installInitialARemb(/dev/sda, , 5)
Fri Nov  8 09:26:57 UTC 2024 call : mkdir -p /mnt/part7 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:57 UTC 2024 call : mount /dev/sda5 /mnt/part7 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:57 UTC 2024 call : cp -f -r /root/BaseAR/* /mnt/part7 (/root/scripts/installInitialARemb.sh:32)
Fri Nov  8 09:26:58 UTC 2024 call : touch /mnt/part7/log.txt (/root/scripts/installInitialARemb.sh:33)
Fri Nov  8 09:26:58 UTC 2024 call : mkdir -p /mnt/part8 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:58 UTC 2024 call : mount /dev/sda6 /mnt/part8 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:58 UTC 2024 call : mkdir -p /mnt/part9 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:58 UTC 2024 call : mount /dev/sda7 /mnt/part9 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:58 UTC 2024 call : mkdir -p /mnt/part8/RPSHD/SYSROM (/root/scripts/installInitialARemb.sh:59)
Fri Nov  8 09:26:58 UTC 2024 call : mkdir -p /mnt/part9/RPSHDS/SYSROM (/root/scripts/installInitialARemb.sh:60)
Fri Nov  8 09:26:58 UTC 2024 call : mv -f /mnt/part7/*.br /mnt/part8/RPSHD/SYSROM (/root/scripts/installInitialARemb.sh:61)
Fri Nov  8 09:26:58 UTC 2024 call : cp -f /mnt/part8/RPSHD/SYSROM/*.br /mnt/part9/RPSHDS/SYSROM (/root/scripts/installInitialARemb.sh:62)
Fri Nov  8 09:26:58 UTC 2024 func : _installTransferModule(/mnt/part8)
Fri Nov  8 09:26:58 UTC 2024 func : getTransferModuleName(transferModuleName)
Fri Nov  8 09:26:58 UTC 2024 func : _getPipConfig(pipConfig)
Fri Nov  8 09:26:58 UTC 2024 call : mkdir -p /mnt/part8/TRANSFER (/root/scripts/installInitialARemb.sh:94)
Fri Nov  8 09:26:58 UTC 2024 call : cp -f /Setup/PIP/artransfer.br /mnt/part8/TRANSFER/artransfer.br (/root/scripts/installInitialARemb.sh:95)
Fri Nov  8 09:26:58 UTC 2024 info : artransfer.br copied
Fri Nov  8 09:26:58 UTC 2024 call : umount /mnt/part9 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:58 UTC 2024 call : rmdir /mnt/part9 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:58 UTC 2024 call : umount /mnt/part8 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:58 UTC 2024 call : rmdir /mnt/part8 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:59 UTC 2024 call : umount /mnt/part7 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:59 UTC 2024 call : rmdir /mnt/part7 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:59 UTC 2024 info : ARemb installed
Fri Nov  8 09:26:59 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 50%
Fri Nov  8 09:26:59 UTC 2024 func : installHypervisorFiles(/dev/sda, , 5)
Fri Nov  8 09:26:59 UTC 2024 call : mkdir -p /mnt/part10 (/root/scripts/helper.sh:144)
Fri Nov  8 09:26:59 UTC 2024 call : mount /dev/sda5 /mnt/part10 (/root/scripts/helper.sh:145)
Fri Nov  8 09:26:59 UTC 2024 call : mkdir -p /mnt/part10/SYSTEM/RTH (/root/scripts/hypervisorHelper.sh:30)
Fri Nov  8 09:26:59 UTC 2024 call : cp -f /root/BaseAR/System/RTH/rthx86 /mnt/part10/SYSTEM/RTH/ (/root/scripts/hypervisorHelper.sh:33)
Fri Nov  8 09:26:59 UTC 2024 call : cp -f /root/BaseAR/System/RTH/license.txt /mnt/part10/SYSTEM/RTH/ (/root/scripts/hypervisorHelper.sh:33)
Fri Nov  8 09:26:59 UTC 2024 call : touch /mnt/part10/log.txt (/root/scripts/hypervisorHelper.sh:35)
Fri Nov  8 09:26:59 UTC 2024 call : umount /mnt/part10 (/root/scripts/helper.sh:170)
Fri Nov  8 09:26:59 UTC 2024 call : rmdir /mnt/part10 (/root/scripts/helper.sh:171)
Fri Nov  8 09:26:59 UTC 2024 info : B&R hypervisor installed
Fri Nov  8 09:26:59 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 60%
Fri Nov  8 09:26:59 UTC 2024 func : installUefiGrub2(gposName, bootline, /EFI/grub/efiPartMarker_ACghbPiRj0, /dev/sda, 1)
Fri Nov  8 09:26:59 UTC 2024 call : mkdir -p /boot/efi (/root/scripts/uefiInstallGrub2.sh:20)
Fri Nov  8 09:26:59 UTC 2024 call : mount /dev/sda1 /boot/efi (/root/scripts/uefiInstallGrub2.sh:21)
Fri Nov  8 09:26:59 UTC 2024 log  : used kernel: 5.12.4-x86
Fri Nov  8 09:26:59 UTC 2024 log  : needed kernel: 5.12.4-x86
Fri Nov  8 09:26:59 UTC 2024 call : ln -s /lib/modules/5.12.4-x86 /lib/modules/5.12.4-x86 (/root/scripts/uefiInstallGrub2.sh:29)
Fri Nov  8 09:26:59 UTC 2024 call : grub-install --target=x86_64-efi --efi-directory=/boot/efi --directory=/usr/lib/grub/x86_64-efi --locale-directory=/usr/share/locale --boot-directory=/boot/efi/EFI --bootloader-id=BR\ Hypervisor (/root/scripts/uefiInstallGrub2.sh:32)
Fri Nov  8 09:27:01 UTC 2024 func : getEspPartition(espDevice, espPartNr)
Fri Nov  8 09:27:01 UTC 2024 func : getAhciPort(ahciPort, /dev/sda)
Fri Nov  8 09:27:01 UTC 2024 func : logWriteAddUninstallCmd(delDir 0 1 "/EFI/grub")
Fri Nov  8 09:27:01 UTC 2024 func : getEspPartition(espDev, espPart)
Fri Nov  8 09:27:01 UTC 2024 log  : ESP: /dev/sda 1
Fri Nov  8 09:27:01 UTC 2024 call : mkdir -p /mnt/part11 (/root/scripts/helper.sh:144)
Fri Nov  8 09:27:01 UTC 2024 call : mount /dev/sda1 /mnt/part11 (/root/scripts/helper.sh:145)
Fri Nov  8 09:27:01 UTC 2024 log  : adding entry for uninstallation "echo delDir 0 1 "/EFI/grub"" into /mnt/part11/uninstall.cfg
Fri Nov  8 09:27:01 UTC 2024 call : umount /mnt/part11 (/root/scripts/helper.sh:170)
Fri Nov  8 09:27:01 UTC 2024 call : rmdir /mnt/part11 (/root/scripts/helper.sh:171)
Fri Nov  8 09:27:01 UTC 2024 func : logWriteAddUninstallCmd(delDir 0 1 "/EFI/BR Hypervisor")
Fri Nov  8 09:27:01 UTC 2024 call : mkdir -p /mnt/part12 (/root/scripts/helper.sh:144)
Fri Nov  8 09:27:01 UTC 2024 call : mount /dev/sda1 /mnt/part12 (/root/scripts/helper.sh:145)
Fri Nov  8 09:27:01 UTC 2024 log  : adding entry for uninstallation "echo delDir 0 1 "/EFI/BR Hypervisor"" into /mnt/part12/uninstall.cfg
Fri Nov  8 09:27:01 UTC 2024 call : umount /mnt/part12 (/root/scripts/helper.sh:170)
Fri Nov  8 09:27:01 UTC 2024 call : rmdir /mnt/part12 (/root/scripts/helper.sh:171)
Fri Nov  8 09:27:01 UTC 2024 func : logWriteAddUninstallCmd(delEfiBootEntry "BR Hypervisor")
Fri Nov  8 09:27:01 UTC 2024 call : mkdir -p /mnt/part13 (/root/scripts/helper.sh:144)
Fri Nov  8 09:27:01 UTC 2024 call : mount /dev/sda1 /mnt/part13 (/root/scripts/helper.sh:145)
Fri Nov  8 09:27:01 UTC 2024 log  : adding entry for uninstallation "echo delEfiBootEntry "BR Hypervisor"" into /mnt/part13/uninstall.cfg
Fri Nov  8 09:27:01 UTC 2024 call : umount /mnt/part13 (/root/scripts/helper.sh:170)
Fri Nov  8 09:27:01 UTC 2024 call : rmdir /mnt/part13 (/root/scripts/helper.sh:171)
Fri Nov  8 09:27:01 UTC 2024 call : cp /boot/efi/EFI/BR\ Hypervisor/grubx64.efi /boot/efi/EFI/grub/efiPartMarker_ACghbPiRj0 (/root/scripts/uefiInstallGrub2.sh:45)
Fri Nov  8 09:27:01 UTC 2024 call : umount /boot/efi (/root/scripts/uefiInstallGrub2.sh:46)
Fri Nov  8 09:27:01 UTC 2024 call : rmdir /boot/efi (/root/scripts/uefiInstallGrub2.sh:47)
Fri Nov  8 09:27:01 UTC 2024 call : rmdir /boot (/root/scripts/uefiInstallGrub2.sh:48)
Fri Nov  8 09:27:01 UTC 2024 call : mkdir -p /mnt/part14 (/root/scripts/helper.sh:144)
Fri Nov  8 09:27:01 UTC 2024 call : mount /dev/sda1 /mnt/part14 (/root/scripts/helper.sh:145)
Fri Nov  8 09:27:01 UTC 2024 func : _createGrub2Cfg(gpos, /mnt/part14, /mnt/part14/EFI/grub/grub.cfg, /EFI/grub/efiPartMarker_ACghbPiRj0)
Fri Nov  8 09:27:01 UTC 2024 func : copyWindowsEfiDir(/mnt/part14)
Fri Nov  8 09:27:01 UTC 2024 call : cp -r /mnt/part14/EFI/* /mnt/part14/EFI.saved (/root/scripts/uefiEsp.sh:89)
cp: can't create directory '/mnt/part14/EFI.saved/BR Hypervisor': No such file or directory
cp: can't create directory '/mnt/part14/EFI.saved/Boot': No such file or directory
cp: can't create directory '/mnt/part14/EFI.saved/Microsoft': No such file or directory
cp: can't create directory '/mnt/part14/EFI.saved/grub': No such file or directory
Fri Nov  8 09:27:01 UTC 2024 log  : adding grub2 entry for rth with windows
Fri Nov  8 09:27:01 UTC 2024 log  : adding grub2 entry for ARemb
Fri Nov  8 09:27:01 UTC 2024 log  : adding grub2 defaults
Fri Nov  8 09:27:01 UTC 2024 log  : /mnt/part14/EFI/grub/grub.cfg:
Fri Nov  8 09:27:01 UTC 2024 log  :     search -f /EFI/grub/efiPartMarker_ACghbPiRj0 -s efiPart
Fri Nov  8 09:27:01 UTC 2024 log  :     regexp --set=1:diskHint "(hd[0-9]{1,2},)" "${efiPart}"
Fri Nov  8 09:27:01 UTC 2024 log  :     menuentry "Windows" {
Fri Nov  8 09:27:01 UTC 2024 log  :         root=$efiPart
Fri Nov  8 09:27:01 UTC 2024 log  :         chainloader /EFI/Microsoft/Boot/bootmgfw.efi
Fri Nov  8 09:27:01 UTC 2024 log  :         boot
Fri Nov  8 09:27:01 UTC 2024 log  :     }
Fri Nov  8 09:27:01 UTC 2024 log  :     menuentry "BR Hypervisor" {
Fri Nov  8 09:27:01 UTC 2024 log  :         insmod all_video
Fri Nov  8 09:27:01 UTC 2024 log  :         search -f   /SYSTEM/RTH/rthx86 -s -h $diskHint
Fri Nov  8 09:27:01 UTC 2024 log  :         multiboot2  /SYSTEM/RTH/rthx86 loglevel=8 tracefile=log.txt
Fri Nov  8 09:27:01 UTC 2024 log  :         module2     /SYSTEM/RTH/license.txt
Fri Nov  8 09:27:01 UTC 2024 log  :         module2     /SYSTEM/RTH/ARemb.txt
Fri Nov  8 09:27:01 UTC 2024 log  :         module2     /arimg          arimg
Fri Nov  8 09:27:01 UTC 2024 log  :         module2     /EFI/Microsoft/Boot/bootmgfw.efi /EFI/grub/efiPartMarker_ACghbPiRj0
Fri Nov  8 09:27:01 UTC 2024 log  :     set timeout=1
Fri Nov  8 09:27:01 UTC 2024 log  :     set default="BR Hypervisor"
Fri Nov  8 09:27:01 UTC 2024 call : umount /mnt/part14 (/root/scripts/uefiInstallGrub2.sh:62)
Fri Nov  8 09:27:01 UTC 2024 info : Grub2 installed
Fri Nov  8 09:27:01 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 80%
Fri Nov  8 09:27:01 UTC 2024 func : installUefiHypervisorCfg(/dev/sda, /dev/sda, , 5, efiPartMarker_ACghbPiRj0, Windows, )
Fri Nov  8 09:27:01 UTC 2024 call : mkdir -p /mnt/part15 (/root/scripts/helper.sh:144)
Fri Nov  8 09:27:01 UTC 2024 call : mount /dev/sda5 /mnt/part15 (/root/scripts/helper.sh:145)
Fri Nov  8 09:27:01 UTC 2024 func : createRthCfgHeader(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 log  : creating RTH config file header: createRthCfgHeader(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : getPciDriveParameters(pciBus, pciDevice, pciFunction)
Fri Nov  8 09:27:01 UTC 2024 log  : drive parameters: (00:17:0)
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgDriveEntry(/dev/sda, /dev/sda, 4, /mnt/part15/SYSTEM/RTH/ARemb.txt, 00, 17, 0)
Fri Nov  8 09:27:01 UTC 2024 func : _writeRthCfgDrivePartitionEntry(0, 4, /mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : _writeRthCfgDriveEntry(00, 17, 0, 0, 0, /mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : _writeRthCfgDriveEntry(00, 17, 0, 1, 1, /mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : _writeRthCfgDriveEntry(00, 17, 0, 2, 2, /mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgIoRanges(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 log  : adding entries for IO ranges: addRthCfgIoRanges(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgIoRangeMtcx(/mnt/part15/SYSTEM/RTH/ARemb.txt, 0)
Fri Nov  8 09:27:01 UTC 2024 log  : adding IO range entry for MTCX
Second Part:
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgIoRangeNmi(/mnt/part15/SYSTEM/RTH/ARemb.txt, 1)
Fri Nov  8 09:27:01 UTC 2024 log  : adding IO range entry for NMI
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgIoRangePostCodes(/mnt/part15/SYSTEM/RTH/ARemb.txt, 2)
Fri Nov  8 09:27:01 UTC 2024 log  : adding IO range entry for POST codes
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgIoRangePiix(/mnt/part15/SYSTEM/RTH/ARemb.txt, 3)
Fri Nov  8 09:27:01 UTC 2024 log  : adding IO range entry for PIIX driver
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgIRQ(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 log  : adding entry for IRQ: addRthCfgIRQ(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 log  : adding RTH cfg GPOS image entry and bootline
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgOsEntries(Windows, /mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 log  : adding OS entries: addRthCfgOsEntries(Windows, /mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : _addRthCfgPciDefaults(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgShmEntries(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgSystemEntries(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 func : addRthCfgTimeSyncEntries(/mnt/part15/SYSTEM/RTH/ARemb.txt)
Fri Nov  8 09:27:01 UTC 2024 log  : /mnt/part15/SYSTEM/RTH/ARemb.txt:
Fri Nov  8 09:27:01 UTC 2024 log  :     # RTH CONFIG
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/0/PARTITION/4]
Fri Nov  8 09:27:01 UTC 2024 log  :         "OS"                     = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/0/PARTITION/5]
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/0/PARTITION/6]
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/0/PARTITION/7]
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "bus"                    = uint32: 0x00
Fri Nov  8 09:27:01 UTC 2024 log  :         "default"                = uint32: 0
Fri Nov  8 09:27:01 UTC 2024 log  :         "device"                 = uint32: 0x17
Fri Nov  8 09:27:01 UTC 2024 log  :         "function"               = uint32: 0x0
Fri Nov  8 09:27:01 UTC 2024 log  :         "port"                   = uint32: 0x0
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/1]
Fri Nov  8 09:27:01 UTC 2024 log  :         "port"                   = uint32: 0x1
Fri Nov  8 09:27:01 UTC 2024 log  :     [/DRIVE/2]
Fri Nov  8 09:27:01 UTC 2024 log  :         "port"                   = uint32: 0x2
Fri Nov  8 09:27:01 UTC 2024 log  :     # IO range for MTCX
Fri Nov  8 09:27:01 UTC 2024 log  :     [/IO_RANGE/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "base_port"              = uint32: 0x4000
Fri Nov  8 09:27:01 UTC 2024 log  :         "length"                 = uint32: 0x0200
Fri Nov  8 09:27:01 UTC 2024 log  :         "shared"                 = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :     # IO range for NMI
Fri Nov  8 09:27:01 UTC 2024 log  :     [/IO_RANGE/1]
Fri Nov  8 09:27:01 UTC 2024 log  :         "base_port"              = uint32: 0x61
Fri Nov  8 09:27:01 UTC 2024 log  :         "length"                 = uint32: 0x0001
Fri Nov  8 09:27:01 UTC 2024 log  :     # share IO range for POST codes
Fri Nov  8 09:27:01 UTC 2024 log  :     [/IO_RANGE/2]
Fri Nov  8 09:27:01 UTC 2024 log  :         "base_port"              = uint32: 0x80
Fri Nov  8 09:27:01 UTC 2024 log  :     # IO range for I82371AB_DELAY() in vxbPiixStorage driver
Fri Nov  8 09:27:01 UTC 2024 log  :     [/IO_RANGE/3]
Fri Nov  8 09:27:01 UTC 2024 log  :         "base_port"              = uint32: 0x84
Fri Nov  8 09:27:01 UTC 2024 log  :     [/IRQ]
Fri Nov  8 09:27:01 UTC 2024 log  :         "USB_SMI_disable"        = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :         "default"                = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :     [/OS/0/RUNTIME/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "image_0"                = "efiPartMarker_ACghbPiRj0"
Fri Nov  8 09:27:01 UTC 2024 log  :     [/OS/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "boot_priority"          = uint32: 0
Fri Nov  8 09:27:01 UTC 2024 log  :         "name"                   = "Windows"
Fri Nov  8 09:27:01 UTC 2024 log  :         "trace_partition_number" = uint32: 0
Fri Nov  8 09:27:01 UTC 2024 log  :         "virtualized"            = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :     [/OS/1/RUNTIME/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "bootline"               = "vnet(0,0) e=192.168.2.2"
Fri Nov  8 09:27:01 UTC 2024 log  :         "image_0"                = "arimg"
Fri Nov  8 09:27:01 UTC 2024 log  :         "max_image_size_0"       = uint32: 0x2000000
Fri Nov  8 09:27:01 UTC 2024 log  :     [/OS/1]
Fri Nov  8 09:27:01 UTC 2024 log  :         "SMT"                    = uint32: 0
Fri Nov  8 09:27:01 UTC 2024 log  :         "boot_priority"          = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :         "cores"                  = bytelist: 1
Fri Nov  8 09:27:01 UTC 2024 log  :         "memory_size"            = uint64: 536870912
Fri Nov  8 09:27:01 UTC 2024 log  :         "name"                   = "ARemb"
Fri Nov  8 09:27:01 UTC 2024 log  :         "restricted_IO"          = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :         "virtual_MMU"            = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :     [/PCI/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "vendor_ID"              = uint32: 0x1677
Fri Nov  8 09:27:01 UTC 2024 log  :     [/PCI]
Fri Nov  8 09:27:01 UTC 2024 log  :     [/SHM/0]
Fri Nov  8 09:27:01 UTC 2024 log  :         "name"                   = "trace"
Fri Nov  8 09:27:01 UTC 2024 log  :         "size"                   = uint64: 0x4000
Fri Nov  8 09:27:01 UTC 2024 log  :     [/SYSTEM]
Fri Nov  8 09:27:01 UTC 2024 log  :         "IOMMU"                  = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :     [/TIME_SYNC]
Fri Nov  8 09:27:01 UTC 2024 log  :         "auto_start"             = uint32: 1
Fri Nov  8 09:27:01 UTC 2024 log  :         "master"                 = uint32: 0
Fri Nov  8 09:27:01 UTC 2024 log  :         "sync_interval"          = uint32: 1000
Fri Nov  8 09:27:01 UTC 2024 call : umount /mnt/part15 (/root/scripts/helper.sh:170)
Fri Nov  8 09:27:01 UTC 2024 call : rmdir /mnt/part15 (/root/scripts/helper.sh:171)
Fri Nov  8 09:27:01 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 90%
Fri Nov  8 09:27:01 UTC 2024 info : B&R Hypervisor installation finished.
Fri Nov  8 09:27:01 UTC 2024 log  : \nB&R Hypervisor is going to be installed. 100%
Fri Nov  8 09:27:01 UTC 2024 log  : ok reboot dialog: B&R Hypervisor Installation finished - Installation successfully completed.
what is the output Window now? can you provide printscreen?
Im out of idea tbh. So you will probably need to get in contact with local office B&R support.
Hmm okay, I will do that. Thanks for your time. If I happen to solve the problem, I will update this post.
That would be perfect. Im sure it is something small, …but the error is not self explaining tbh.
