Introducing how many mm the engine will travel when completing 1 revolution
Hello
While there is MpAxisTransfomationTyp block in ACP10, I cannot find what is this block in Mappmotion? I will write how many mm the engine will travel when it completes 1 revolution.
in mapp Motion the “Reference distance” is set the Axis HW Configuration:
Yes, I want that function, sometimes it can be changed so that it can be entered from the screen.
Thank you for your information
Apologies, I mixed up the Axis configuration and the Axis Hardware configuration. Martin’s answer is the correct one.
If you want to change the values at runtime, you can use the MpAxisBasicConfig function block from the mapp Motion MpAxis library.
