Is it possible to replace 8AC110.60-2 with 8AC110.60-3?
Hello:
Is it possible to replace the 8AC110.60-2 with the 8AC110.60-3 if I don’t have the source program to change the hardware configuration?
Hello Wenjie,
8AC110.60-2 will be replaced by 8AC110.60-3; Compatible replacement
There should be nothing else necessary from your side than replacing the module.
Thanks,that’s very helpful.
I can also confirm that the 8AC110.60-3 is a drop-in replacement for the 8AC110.60-2, so no software changes are required!
