Latest AS 4.12.6 as upgrade?
Hallo,
will the latest version be offered as upgrade?
until now its only available as full install …
many thanks,
Torsten
The latest AS 4.12.6 will only be offered as a full install due to some cyber security related issues requiring a full clean installation to fix them.
Btw: the download/install of 4.12.6 triggered some malware warning on my site. I got a call from our IT dept and we are now scanning the PC …
Now with AS 4.12.6 installed I often get certificate error when installing updates:
Is it a known issue? Can the updates be installed anyway for now?
I can acknowledge that for the AS4_LIB_MTBasics.exe i see the same behaviour.
If you press Start Installation, Windows will ask you if you trust the installation and you can continue if you want.
A clarification like this is not up to the community. Its a behaviour which has to be clarified by regular B&R support, it could also be a potential cyber security topic.
Can you please set a request to you local office.
FYI, the installation of AS 4.12.6 causes a re-compile for all of my projects.
Not sure if that only happens for C programming language tasks.
