Where is the service pack 6 for AS4.12
Hello Community,
I had installed AS 4.12. I installed service pack 4.12.5.95_SP few month ago … and now I see on the website there is AS 4.12.6.106 … only the full version … where is the service pack for this version …
Or I will must install the full version … ;-(
Thanks in advance
Hi Alexandre,
there is no SP6, for that you’ll have to use the full installer.
due to a Cyber Security Topic AS4.12.6 is only available as a Full Install.
To use it, you must Uninstall AS4.12.5 before.
The main change is that AS4.12 uses a different installation location.
Is there any relevance to the location?? I just installed it over 4.12.5 and used the same location as before! (C:\BrAutomation) xD
There is a relevance.
“BrAutomation” is not under the control of the curent Windows user and can therefor be modified by ANY user of this PC.
For Cyber security reasons we changed this to a folder with UAC
I am not an IT specialist. I got the information that the new standard location "C:\Program Files" is better protected by Windows.
Ah, thanks for the explanation!
