Licensing error
The license for Automation Studio software has expired.“Create update failed.it is not possible to create an update from an old cmActLicense context(Firmcode:5000248)” and "The request was aborted:- could not create SSL/TLS secure channel."errors are being displayed while activating the new license for all software versions.Please provide a solution.
Hello Sona,
the search function does work and only searching for your error code already yields a result:
Only if searching doesn’t work, please post your issue - and if the original thread has a certain age and already has been marked as solved please do create a new topic - as the box to the right of your new post would have told you.
I have moved the post to a new topic, please let us know if the linked solution does work.
I just realized you did create a new topic additionally.
Unlisting this one
