Mapp Audit - How filter list by incomplete name?
Hello all,
I used the component mapp Audit.
Can it filter by incomplete name?
For example, users with “a” in their name.
How should I write it there to filter it out?
It only works for me if I write the full user name there, e.g. “admin”.
I tried e.g. “a” or " a ", but that doesn’t work. The result is an empty list.
@Lubos_Sadlon Hello Lubos welcome to the B&R community
Not sure if you have tried wildcards? There is a note in the help about that but not specifically for filters other then messages
Specifies the event message. Wildcard "" can be used. For additional information about this value, see section “Filtering events” in the description*
Thank you for your answer.
It works, I just have to type it into the pattern box.
